2013 Sau Vic Annual Renewal/dyno Day
Sunkist
 Share
  • Replies 245
So turns out my flight is a little later in the day to what I expected.
So as long as no-one complains if I'm first on the dyno I'm in..
payment just made.
Low cars should be fine, just look at how long and easy the tracks up to the dyno are:
901C85B7-39AD-41C0-996C-13C738F181AB-172
Having said that, the owners are car enthusiasts and if a car is too low I'm sure they will accommodate for that too
Well done with the thread Aaron! It will be a great day :D
nick should lower his car more then.... :devil:
why arent you entering?!
naice, ok well I'll probably go for lowest kw then..... Try get a laugh too with my soot chucker tdi
Will pay tomorrow when I'm doing my banking
Awesome!! see you there
i will come along...i will enter if i find 60$ laying around anywhere... :) we can enter on the day yeah?
It's about about 40mm lowest, but can't go any more
driveshaft hits the chassis :P
niiiiice...i got about 60mm but thats just a stupidly low exhaust...i need a new one...
haha yeah my exhaust tucks up well, it's my crossmember that's low
yep on the day is fine, but will need to cancel without enough pre entries :(..
oh really...how many more you need...
are we talking about the Gulf...
*actually yes i think i saw pictures of it somewhere...post your ride thread yeah?
 Share
    • Tryna decide if I should get a skirt coating on my cp 2618 forged pistons that im about to order. Anyone have first hand experience with a forged RB with coated or non coated piston skirts? Is it worth it and does it make much difference? And for people who went with 2618 pistons with no skirt coating how long has your engine lasted? The engine is an rb25/30 and main concern is  that It will be a daily car and will probably see a fair bit of short distance driving, have been told by my machine shop and my tuner that generally a forged engine lasts around 40,000kms before needing a rebuild. Would a skirt coating make much of a difference? cheers
    • From now on read it as minus 5 and minus 7 instead of dash, and you're correct...
    • Opened up the cluster to inspect the gauge itself for signs of damage and it looks good. Got curious since that needle doesn't go back to a "neutral" position by itself (it stays in the same position when ignition is off. so I manually moved it to 1/2. Connected it back, turned on the ignition and the needle started moving up! Not sure what's up with that but before that the needle was way down below empty like fully south west. There's always a chance that the needle moved slightly the first time I tried and I didn't notice because of how slowly it moves and how far it was from the markings. I don't know if the current needle position is accurate so I'll fill it up and see where that brings it. I guess I'll try to adjust it manually if it doesn't get to F. Looks like the needle position is relative and not absolute? Thanks all for your help and patience!
    • You're confusing two different responders and more than one issue. The stock Neo ECU boost sensor is used by the ECU for protection purposes. It is essentially only an overboost sensor. It is not used for determining engine load for fuelling or ignition purposes. That task falls solely to the AFM. Any aftermarket ECU that either has an onboard MAP sensor or a plug in one, will use the MAP sensor as the primary load sensor. Or I should perhaps say "can", rather than "will", because some of them have the option of using other primary load sensors. That MAP sensor is not for the same function as the stock Neo boost sensor. The reason I recommended against a plug and play ECU is that they are intended to run a particular engine and usually in the car that the particular engine came in. So, if you have a transplanted engine in a different car, with some parts of the original missing (such as the boost sensor, for example) and therefore likely non-standardness of the loom and its insertion into the car's loom, then it is very likely that you will run into the same problems with needing to fix up wiring to make it work that you would with the stock ECU. And, if doing so for the stock ECU is enough of an obstacle that you start considering a standalone plugin as a solution, it should become clear that the plugin is quite possibly not the solution you'd hope it to be. It would just lead to more of the same type of problem solving work to get it going. In the above paragraph and in my earlier post, the lack of the boost sensor is not critical. It was just used as an example of something that we knew you did not have right, such that the stock ECU would not work. I took that as an indicator of a reasonable probability that there were other related problems hiding there.
    • I can think of two places in my city of <1.5million population that specialise in automotive instrument repairs.Unless you're out in the wilds of Quebec, you have 3 major Canadian and 3 major US cities within the same distance as the single nearest city to mine. Surely there is somewhere you could send it.
