  • Replies 119
Well based on that I'm in the 12-15 range then so maybe the scales are OK.
The 10-12 is leaner than me, but I'm leaner than the 15 guy.
Edited by ActionDan
OK after having a proper go at that routine, it took 53mins, including keeping in my previous ab work and the dips because I like those at the end.
The order taken was.
stretch
crunches
squats (as mentioned these are quite hard on my ankle at the moment so only 25kg and only parallel, I also have to have my feet at roughly 45 degrees, further in i go the worse my ankle protests)
bench
SLDL
overhead press
ab work
bb curls
bb rows
bench style dips
Taking 2min breaks, I can see I'll be able to add weight to pretty much everything, but will hold off for now while some back/shoulder/arm twinges go away (from working on the car flat out lately).
I don't get the same pump after a workout as I did, especially in the bicep area, hopefully that will change a bit when i up the weight on a few things as im doing everything fairly light on.
Pump isn't a reflection of a good workout though. It's just a mental thing.
Do weighted chins and see if you get bicep pump.
Also, how are these twinges going away? Just because the pain eases doesn't mean the knotted muscle or impinged nerve does. Get a decent treatment.
Have you thought about doing conventional dead lifts? Or are they another day? Just thinking they will work your ankle a bit driving through the feet
It will change as you up the weights. The other day I set PBs in deadlifts and I struggled bad on barbell curls. Gotta remember that a "pump" does not mean you've worked harder or lifted more.
Recommend sticking crunches and barbell curls at the end too. You did curls before rows, which recruit biceps. Always do the compounds first and finish with isolation...start from the core and work out to the limbs.
Yeah fair point re pump. I'm looking around for a cage with a chin up bar and dip station.
I rub and stretch out twinges myself usually. If an exercise movement is not aggravating it then I've usually done it working on the car etc so it goes away in time when I get a chance to rest.
I'm doing SLs because they were what was listed in starting strength, probably easier on the back too?
The ankle gets plenty of work via squats and 3k walk with some light jogging thrown in each day, the surgeon said it takes a good 12mths to come back from what I didi, it's only been 4.
Yeah I can move curls to last easy enough,I thought I was showing some real dedication putting them fairly towards the end and doing squats first lol I've also tried to break it up with push/pull alternating to an extent.
Why move crunches? They help me warm up.
just do all your CAARMING at home instead of at the gym.
Home = gym but what is Caarming?
Have you ever known someone to pull their abs during a workout? You use them every minute of the day, you don't need to warm them up. You do, however, need them for compound exercises...so there's no point wearing them out in isolation...just like biceps. The common theme here is that if you are lifting heavy enough on the compounds, you'll barely be able to do the isolation because the muscle group has already been used.
Good work on alternatIng push and pull...definitely works well for me breaking things up like that. But yeah, compound first, isolation last.
As for the pump, as jangles said it's all mental...as are a lot of your habits like crunches to warm up. Forget that dude who said it, but fitness industry is a breeding ground for OCD behaviour. We get good results and misattribute everything we do towards them, including the pointless shit. Less is sometimes more, it's about working out smarter rather than harder. More important is that you have lifted more weight rather than how faxed you feel or tight your biceps are.
I've never pulled an ab but I've always done ab work. I'm not warming up the abs, just warming up myself.
I never used to put the crunches first, I only started doing it with this routine to switch things up and it helps me get blood flowing and a light sweat going, I can move it anywhere as I couldn't care less when/where I do it, I just don't like to start out with a heavy motion straight off the bat.
you don't know what CAARMING is?
youtube - Arnie the pump
Also - SLDL is not in starting strength. the program listed on the earlier pages is not from starting strength.
edit - seems all your injuries/twinges etc come from that anchor you call a motor.
Fit a VH45 and win at life.
Edited by TTT
Bad luck. Start out with a compound movement. That's what warm up sets are for. Your crunches are doing nothing but costing you good lifts, so stick them at the end. I stretch my arms and then it's straight into an 85kg bench for 10 reps. What makes me better than you, captain crunch?
Warm up sets arguably cost good lifts too...
I'm surprised, I thought you guys would be into warming up, good way to avoid injury which is why i do it now, that and being 30 means I'm not as injury resistant as I used to be.
Edited by ActionDan
Haven't trained abs in years cause I know squatting uses your core like a motherf**ker. Good thing is most compound movements will work your core since that area is for stability.
The program listed is something Markos put together for beginners to lifting.
Starting Strength has even less volume and therefore less pump so you'd go crazy.
Edit - doing crunches is not a warm up for any exercise.
how would doing multiple bending of the middle be a warm up for anything you will use during any of the exercises listed in the program?
Edited by TTT
We do warm up, with warm up sets.
Can you explain how crunches are going to stop a shoulder injury from bench or a leg injury in deads and squats? If anything they are more likely to cause injury, because you are weakening your core before doing big lifts. You need to have a tight core during squats and deads else you can end up with injury when you're going heavy. Warm up by doing the exercise lightly...you're not going to hurt anything by doing this.
It's like I said in my previous post, there's a whole heap of stuff you're misattributing to success...need to break the mental barriers.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
