Hey Guys,
Just wanted to see if anyone else with a v35 coupe (mines 2004) experience problems with their air con?
Mine seems to work fine most of the times i use it whether it be on a 20 degree day or 28 degrees but it seems to stop working anything above 30 degrees?
Like it would start working for a while and then blow out hot air, and it seems to be more frequent when I come to a stop? it seems like it works then stops to recharge itself and then blow cold air again after maybe 10 mins or so?
Please advise what the problem could be? or is it cause its just too hot that the aircon stops running, that and cause its a black car? LOL annoying when im sitting in the car melting....
thanks
https://www.sau.com.au/forums/topic/420204-air-conditioning-issues/
Sounds like one of both of your thermo fans is not working (or not working properly). I have a black 03 coupe and over 35 degrees the a/c will click off if I sit around idling for 10 minutes or more, but it is fine no matter what length of time I idle under 35 degrees. If your thermos are working, perhaps try getting some compressed air onto you radiator and your a/c radiator - the a/c radiator particularly could be full of bugs or dirt, and is not working effectively. Then get your gas checked - there is every chance your gas is low, thus reducing the effifiency of your a/c and making it work too hard - hence shutting off due to heat earlier than usual.
If it is stinking hot and I am planning on idling for an extended period (or the car is really hot), I will often pop the bonnet and pour/spray water out of a water bottle onto the a/c radiator - makes it work 100% better for a short period of time - the air comes out ICY.
^^ what he said..
Sounds like the condensor isn't getting rid of the heat and the AC system is tripping off on high pressure. As Andrew said.. check thermo fans first.. then check the front of the condensor for bugs/leaves/sticks/etc..
The system won't work as well at idle, and the air probably warms up a little between the evaporator and the outlet.. the temp sensor, post evaporator on my old J30 Maxima used to hit 4 deg.
About 10+ years back I had a car with air-con but without climate control. When I got the air-con re-gassed, the shop would test it with the windows closed and on re-circulate, and the temp coming out of the vents would drop to 4 deg. Things have definitely changed over the years...
The V35 also uses a variable displacement compressor, so it can adjust the cooling power based on requirements. the older style compressors were just on or off.. full cooling power, or none at all, even if they had climate control.
  • 4 weeks later...
Hi guys i encountered a major issue yesterday i was driving the v35 coupe in 30 degree temperatures with the a/c on full blast and then o noticed smoke coming from the front right hand side of the engine bay and the temp gauge was at HIGH i opemd the bonnet and noticed the coolant fluid was bubbling.... could you please advise what the problem could be, i havent had the chance to take it to the mechanic as yet.... hope its an easy fix this is a result of the above issue i had previously with the ac thanks
I think coolant was changed roughly 10k ago? But through reserch there seems to be afew issuesthat could be the cause
Thermostat blocked? Fan clutch? Air bubbles? Fan? Condenser clogged i really want to know what the issue is so i can try amd fix it first rathen thn take it straight to the garage
It is very hard to flush the coolant system, unless you know where the drain bung for the block is located. The thermostat isn't hard to remove and test, mind you the kettle doesn't get the water hot enough, you would need to stick it in a pot on the stove.
I would try a thorough system bleed, topping up the rear bleed point (heater pipe near the firewall) when cold, you may need to do it a few mornings to get all the air out. Beware, the bleed point is a plastic Philips head, and is very easy to strip.
Not without the car here. If you want the system bled properly, see if Craig (Jetwreck) can help. Otherwise go to the mechanic, perhaps get him to do a carbon test on the radiator bubbles just to rule out the head gasket while you are there.
These engines are quite hard to bleed, most mechanics won't do it right. It can take a few days (hot/cold cycles and driving) to get all the air out.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
