Hey guys,
So long story short is that my friend caught 3 people breaking into his car red handed.
The police rocked up and because the people didn't actually have the tool used to pop his lock off they got away.
The car was left with scratches and a damaged lock.
My friend managed to follow the guys back to their car and get a very clear photo of it.
They also told him that he better watch his back and that they will burn his car out next time.
So here are the pictures.
If you see this car or know where it's located I would appreciate if you contact me ASAP on 0408 257 613
https://www.sau.com.au/forums/topic/420432-car-break-in-bruce-area-act/
  • Replies 40
Ah so that's what the Facebook shit was about. Will share! I can't believe they let him take a photo like that without a kerfuffle lol... usually they'd be threatened to delete the photo or had their faces punched in... physical description of ute owners?
Sorry about your friends car Mani :(
Full story:
So my friend decides just before going to bed that he will check on his brand new bike. He looks out the window and sees a persons head pop up from the passenger side of his car. He then flicks off the lights and goes outside while telling his girlfriend to call the police.
He hangs around pretending to talk on the phone waiting for the police to arrive. The police rocked up with the 3 guys still beside his car, they tell the police they needed to do a piss so they went behind the car. Police have no tools used in the breaking of the lock so let the guys go.
My friend ends up calling his girlfriends brother to tell him about it and the brother said he saw the same 3 guys earlier sitting in a white ute. So my friend goes and takes a few photos of the car and notices it already has another bike in the back of it.
He then proceeds to call the police again and they arrive again but can't find any evidence and leave. Just as they leave the 3 guys rock up and get in the car and drive off.
My friend then once again calls the police and the guys are pulled over just up the street. Chances are again the police didn't find anything and they would have been let go again.
Damn, why don't laws protect the farking innocent?
srsly, guys were caught, next to a car with a damaged lock.
they probably threw the jimmy into a neighboring yard and waited.
its a little obvious they weren't taking a piss, there were 3 of them.
who pissed in a group like that.
secondly, they were squatting.
only chicks squat to piss.
third, if you were, you'd pop your head up, apologize, and walk away if you heard someone come out.
I say, if they have prints on your car, that attempted theft and you should be locked up.
hope you find these guys and destroy their lives.
This is all pretty f**ked up and I hope your mate doesn't have to suffer too much financially for someone elses dickheadery.
Karma will catchup with them.
is "karma" a rabbies infected pitbull?
Its always been like this, police never do shit for things like this.
Just before the police came your friend should have started bashing them, get a few hits in and kicks to the face, even if he will get beaten because there are three of them the police will come, break it up and then you can say they jumped you.
I'm having trouble understanding this. So this person calls the police about his car being broken into, police show up and see 3 guys acting suspicious around a car and don't do much about it.
Thought police would take this really seriously.
He didn't know what the outcome was going to be so that's why he called the police.
The guy is actually pretty good at MMA and he was sure he could have taken them out.
Now he knows what the police actually do, next time he won't call the police lol
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
