Not sure on how much fuel you're going to save by swapping but driveability between the two is night and day. Having gone from Sard 800's to ID 2000's there is a significant difference between the two.
Look my injectors idle perfectly and run smoothly (so I think anyways havent really been in a car with id's)
Just get shitty economy. I think im just bitching coz its become my daily for the next month or so
Nothing but problems? Problems like what?
wrong reply lol
alot of failures and having to be replaced. 1000cc and over seems to be where the issues are.. buy 1000cc and you get 6 x 1000cc and 3 only flow 500cc
this has all been on E85 tho so could be part the cause??
Edited by Frosty
And you should have probably returned them, as even Bosch advise less than 2% variation.
You sure they were legit?
these werent mine....and yes returned to fail again. They are still sitting at a workshop here in sydney (half a bucket full to be exact) of various different sizes that have failed under high hp!
all of them in 700hp and above cars
hence why i was asking the question
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
