S A U - N S W Tech Night For Members 24Th Apr - Engine Builds
  • Replies 195
Looking forward to this. Currently under the gun with uni assignments (have a research assignment due the 26th).... but I think I will be good to go for tomorrow. Might have to knock off a touch early from the tech night (around 8.30pm) so apologies in advance for that. Up late now to get as much done as work done as I can.
Bobby has kindly offered finger food for those in a rush.
Don't get a ticket though!
There is no decent place to eat right near JEM so I might have to go a Km away.
Double Demerits has begun.
Haha, 2 hour cruise down the M5 at 5kmph
Lol i really dont want to get stuck in my traffic in my car at the moment :P
There'll be a bogus traffic report through 2GB and 2UE this afternoon that the M5 is "chockers - avoid at all costs".
Ignore the above, and you should get a free run :P
We are coming from Newcastle way and SHOULD be heading against the traffic i hope :yes:
IF i get stuck in traffic you may have reports of people passing out at the wheel due to my ethanol fumes at idle :P
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
