  • Replies 214
have a crack at the next challenge. This one will form an on-going development thread once it's over,so you can give it a go once you are fixed up.
I should be right to have a decent go at this one by end of the month, if not sooner.
I only try the ones that fit into my routine
Do you comment without even looking half the time? Torn hamstring. Powerlifting thread.
l'm sorry for not keeping track of what's going on with your body...
Dim is considered the weakest lifter in our PL team. At under 75kg, he squats 160kg, benches 110kg and deadlifts 200kg, he gets stirred a lot lol
Here is a vid from 2011 of him getting 18 reps with 70kg, his bodyweight then
Gave this a shot tonight after my bench workout. Only managed 9 lol :( Will attempt/film on Thursday when fresh.
80kg x 10
80kg x 10
90kg x 10
95kg x 7
100kg x 4
107.5kg x 2
112.5kg x 1
FML x 1
80kg x 9 (bodyweight challenge)
60kg x 24 (another challenge my basketball friends are doing)
I found the chest touching makes a big difference too. Not that my regular press is much higher off the chest, but just concentrating on every rep touching the chest takes it out of you! Hoping for 20 on Thursday :cheers:
Bout an inch off it according to my training partner.
I think I'm lacking in flexibility, cause I really had to try to get the chest touch happening for the challenge. Have been tucking elbows to nurse my injured shoulder at the moment, which is working well, but it doesn't help with ROM at the bottom of a rep.
All excuses aside, I hope to have something decent on Thurs. Everyone should give this a go, even if you don't film it.
Should my ex or current girlfriend wish to compete
Lulz, you little health and well being whore!
Will do this Thurs, now that I have a later than 6yo 1st gen iPhone I can actually record video!
Can you receive mms now?
Birds - learn to arch back.
then you won't leave an inch between your chest and the bar.
Also - learn to pause bench to practice for the April PTC comp that you will do.
Just pause the first rep of your work sets and carry on with the other reps.
Edited by TTT
I think someone suggested 50 reps would win this, Like I said Ange Galati did 47, and he can bench 200kg raw at 78kg and 262.5kg with a shirt on
I highly doubt anyone will get 30 reps, 20 is a great effort
Equipment can be an issue too. I trained at a gym in the 90's which had 18kg Olympic bars and 25kg plates that weighed 22kg
I told the story on my forum of the guy who claimed to bench 165kg, he missed 140kg in my gym, without a pause
More vids
More vids
I said 50 would be amazing, didn't say it would be winning number tho' lol unless Agne buys a skyline in the next 2 weeks...
20 is great.. I would be stoked to get to 20.
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
