  • Replies 214
Birds
BW: 81kg
BP: 80kg x 15 reps
Was a bit disappointed with this, as I really thought I could push out 20 reps. Would like to give it another go on a better day. All I can say is, for someone who doesn't regularly bench...you're a freak, rev! You'll have to trust me that it was touching the chest, as the filming angle hides the bar and makes it look a bit high (thanks Leigh!). Also, I do not have a hard on :/
http://www.youtube.com/watch?v=6k5Ty1d1vjU
Churs :) that was my second time back on chest after my rotator cuff muscle went super freaky so I'm pretty happy with thy number since I consider myself to be almost back to square one. Will try again next week :)
lol I'd love to blame my shoulder injuries for weakness too, but competitions don't wait for injuries to heal! We both put up our best for now and that's all that matters. Now to improve!
Your muscles will catch up again in no time :)
Eh it's all good practice I guess, probably give this a better crack on Monday I reckon!
You gonna try again? You were raging pretty hard at it affecting our working sets lol
lol I'd love to blame my shoulder injuries for weakness too, but competitions don't wait for injuries to heal! :)
Eh? I wasn't blaming my injury weakness. Was saying my muscles aren't developed because I haven't worked them because of time off due to injury. Have no weakness in the shoulder now.
That's what I was saying too...
Ok, I must have misread 'I'd love to blame my shoulder injuries for weakness too' as being in relation to me
It was in relation to you. My shoulder injuries have cost me valuable time at the gym, I haven't been able to do press movements to keep up my regular weights and consequently I'm a little down on what I can normally do. Was just saying that competitions don't wait for injuries to heal so it's a bit of bad luck for both of us.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
