Okay well tonight I hit 5x140kg on my max set after doing 8x130kg last week. Will do 140kg again next session and I hope to get 6 or 7 of them out.
My 1RM is 170kg, but I haven't attempted 1RM for a few weeks, so it should be a bit higher now that I'm approaching that figure with my working sets. I love how 1RM and working sets compliment each other on a back and forth!
My current goal is a 200kg deadlift @ 80kg, which I'll be very happy with.
Do ppp and you will be there in no time man.
200kg might not seem like anything in the powerlifting scheme of things, but it is definently a tidy 1rm for your average gym goer!
Edited by Mitcho_7
I haven't plateaued yet, so will just keep doing what I'm doing for now. Yeah man, a year ago I didn't think I'd ever lift close to what I'm doing now...stoked! Think I'll be very happy with 200.
Got out 140kg x 6 tonight...grip gave way on the 7th, just before lockout. Afterwards I couldn't open and close my hands, lol! 3 minutes later and I pulled 150kg x 3.
So...should try for 7 next week or crank the weight up and try for 150kg x 5? Be interesting to see how I do on that 1.5 x bw deadlift challenge now...might have to revisit it in a few weeks.
I sit there like a cripple with my hands all closed up for about a minute before they slowly start to open after deads.
Then another minute for the skin to kind of relax.
I reckon low reps and high weight work better for deadlifts.
I want my back and legs to be tired before my hands give way or before it becomes cardio (5 reps plus)
After doing deads in the 8-12 reps range for a while and then doing 5x5 and PPP for deads, I definently like the lower reps. Sets of 5 are probably what I like doing the most, but singles and triples aren't bad to mix it up.
Why not both?
90 x 10
110 x 10
140 x 7
155 x 4
Had no grip issues tonight, cooler weather = no sweat. Next sesh: 160 for reps.
I'm using chalk, whenever I can find it / steal it from the cross fit section at the gym. My grip is never an issue for 1RM attempts, it's the holding of the bar for extended periods of time that seems to do it.
I don't think I have the strength to lift 200 yet. I'd guess 180, maybe 185 based on my 1RM of 170 when I was doing 120 for 10 reps. I will start training the 1RM again soon, though. Took a bit of a break from it when I stretched a back muscle.
Funnily enough, the older ABC bars have better knurling than the new Ironedge bars we have :/
depends on if you are talking 1RM or reping sets and even then you can do sets of 1RM starting at 100% like below
1RM
3sets of 8 - 12 say 100kg
1 x 110kg
1x120kg
1x130kg
and so forth increasing until failure to see what your 1RM is. obviously you get tired but then you would start at say 80% of that 1RM next week
as for 7x2 i ment max weight that you could do for 7 sets would prob be 130kg instead of a 100kg for 3 sets of 8-12
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
