Hi, I am considering the v37 2009 model and understand from reading here that you can't get the navi working or maps for it here. I was looking at the Aus infiniti coupe and it looks to be visually the same navi unit. Has anyone checked the part number and cost of this unit so that it could just be retrofitted to the import and has anyone tried inserting the Aus spec dvd into the import to see if it will read it? Just curious if this is an option and have not seen it discussed.
I had someone in Sydney ring me in this today. It's NOT a direct swap.
You need to change:
Buttons
Controller for butttons,
screen
Navi control unit
Main radio button panel
and roughly $10k in cash.
Max,
tis fine . most people CBF'd reading and prefer to be spoon fed :-)l
  • 1 month later...
All I want is to disable the VSS wires on the foot ("hand") brake from disabling the AUX screen. My 2007 V36 Sedan has the AUX video and Audio inputs in the centre console, so using video out on a phone should be enough for us Navi owners ?
I have seen tutorials of the US car having the handbrake video disabled, but the wires are apparently diferent colours ?
  • 4 weeks later...
Im thinking of getting a v36 non navi for my next car. I am just wanting to know if the stereo is able to connect to an iPod properly and listen to fm radio via an expander and have it being usable? Thanks for any advice
The FM expander works regardless.
What do you mean when you say "work properly" in reference to your iPod? Are you talking about just line level/aux audio input or having full control of your iPod from the OEM stereo controls?
  • 2 months later...
  • 3 weeks later...
A quick note to those finding this in google.
Calling me , getting me to look at the car and then requesting all the part numbers to do the nav swap on a 2011 v36 because you think you can get the parts your self is outright rude. I am not a charity and I will not think twice about calling you out on it.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
