OK so I have this hankering for clear indicators, and I really don't like the D Speed ones. I wanna do em myself, and I know I can do it.
But I lied, I'm not gonna clear MY indicators persay, but... a spare set that have been donated by me by someone who is very confident that I will botch them up and then he will be able to poke fun at me for doing so.
Pics will follow soon.
Oh and lest i forget, a list of shit you'll need:
Bucket (made of a durable plastic that dosen't warp while holding high temperature liquids)
Kettle
Sharpish straight edge screwdriver
Sandpaper of the following Grit: 40, 80, 180, 400, 600, 1000, something higher than 1500
Glass polishing compound
Lots o calories to burn
Place the indicator in a bucket, and make sure the long handle bit points upwards for ease of use when in hot water (as you tend to scald yourself in 100 degree water).
Submerge the indicator underwater for about 10-15 mins, make sure all the bubbles are out, if you put the indicator with the stalk up, then all air will naturally flow out of the holes as you submerge it.
Take the indicator out and drain the water, but don't hold it out of the water for too long as it'll start cooling straight away. The goo is only pliable at around 80 degrees.
This is the easiest place to start and possibly where there's the least goo and the indicator is strongest. Slide the screwdriver in and pushing upward wedge it between the plastic and the housing and push the lens out.
Don't push too much, by now your indicator is probably too cold, wedge something in the gap you've created and start heating the edges of the gap with a hairdryer, progressively wedging and pushing with the screwdriver. A note witht he top end, always wedge the screwdriver as close as possible to the tabs on the top, its very weak in the other places and you'll hear slight creaking noises as the plastic stresses. If you do hear this then stop immediately, heat and try at a stonger point.
Once its off, this is what you'll see.
This is the goo when you heat it with the hairdryer
here are the plastic joints that have been made by meting the plastic guides over the holes that the go thru, to make the inner parts stay on the housing. Basically heat these with a heatgun/hairdryer. I used a 500W beast with a nozzle, so it heats up pretty fast. Once the plastic butts are heated, apply a bit of pressure from the back of the small parts and the butt should snap off with no damage.
Here's ringo with just the lens cover off
Here's the aftermath... Unfortunately tragedy befell Bob, as he was sat on by my mate when he came over on a social visit, which gave him a distinctive crack mark.
Luckily for me, the cracks in a place that dosent matter, and half of Bob's lens will be chopped off to make for a Cold Air Induction inlet. Phew... tragedy averted.
Stay tuned for sanding polishing pics to finish off this guide.
LOL. ;)
Definately keeping an eye on this thread. BTW Shan, what do you use for the nice arrows?
LW.
Arrows = Photoshop -> Custom Shape Tool -> Arrow Shape -> drag to draw one to the desired dimensions.
Right now I'm trying to source a dremel with 40grit bits lol as it'll make my job a WHOLE lot easier.
  • 1 year later...
I did this on one of my sierras.
Predator - the thing that makes the clear bulb glow orange is the bubble thing you refer to, kind of an internal case. As the case omits an orange glow alone, the external cover can be changed from orange to clear.
On some of the older cars the clear bulb doesnt have that orange bubble case thing and relies on just the plastic of the lens. That is why on some older holdens and fords the rear lights come accross as white/clear instead of red or orange.
GDZ1LA, i used the sandpaper to sand the diffusers out of the inside of the indicator. then buffed it like crazy to get a completely clear indicator.
pred, yeah the orange bubbles make em glow orange. some guys prefer to smash it out using a screwdriver thru the hole, but this way's a lot cleaner.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
