Update: BR series Bc coilovers (8mm/kg fronts 6mm/kg rears) ordered, big thanks to Dan at Option 1 great guy to deal with :)
Neat conversion mate, Who done the fab work for engine/trans mounts and is there much room to play with regarding gearbox and the tunnel?
Mark through Home Grown Customs in Toowoomba did the majority of the fab work, the trans tunnel needed a bit of persuasion to push it out a bit as the engine is as far back as I can get it.
Your thread needs more skid vids man! Ill do one soon once my car gets tuned! Your bogan beast should be the burnout warrior :yes:
Rear tires are alllllmost cactus, I'm doing a happy laps at qr next Sunday ill get some fly by videos done up :)
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
