Update: BR series Bc coilovers (8mm/kg fronts 6mm/kg rears) ordered, big thanks to Dan at Option 1 great guy to deal with :)
Neat conversion mate, Who done the fab work for engine/trans mounts and is there much room to play with regarding gearbox and the tunnel?
Mark through Home Grown Customs in Toowoomba did the majority of the fab work, the trans tunnel needed a bit of persuasion to push it out a bit as the engine is as far back as I can get it.
Your thread needs more skid vids man! Ill do one soon once my car gets tuned! Your bogan beast should be the burnout warrior :yes:
Rear tires are alllllmost cactus, I'm doing a happy laps at qr next Sunday ill get some fly by videos done up :)
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
    • You can trust Rezz!
    • Just to get this straight if you turn the splined shaft to the outside, it turns freely but the chain does not move? What happens when you move the chain, does the splined shaft turn? Surely the shaft is snapped, or the chain is seized and it took the teeth off whatever great is behind the steel bracket
