So ghey. Needs more 1JZ foo!
See you Sundy big guy. :wub:
How about an sr20 cortina ;)
But yes definitely keen for Sunday, I should fix this exhaust leak but don't want up fark anything up before then.
i fitted my front camber arms yesterday and wound a bit of neg into it (moreso for looks lol)
Also had it out for qr happy laps today, and it went well for being what is essentially a stock motor. My battery clamp broke so I couldn't corner to hard also cooked my pissy Natro brakes and my rears tires are now catus :thumbsup:
*note shit house front fitment as my 30mm bolt ons rub to much, so I took them off and will purchase a set of 20mm
The car looked like it went well man! Whats next on the menu?
Yer I was really happy with it, went really well for a stock motor. Next on menu in no particular order:
New tires
New brake pads
New front wheel studs and spacers
TO FIX THIS BLOODY GEARBOX!
New tires
New brake pads
stoopid question.... your gbox prob and tacho probs.... they couldnt be related could they? speed sensor issues etc?
just a thought honky!
His speed and tacho probs are just that the signal going to the gauges is wrong.
The correct signal is getting to the ECU which is doing shifts. The ECU has identified a fault with Soln A in the box, and hence locked it out.
didnt know it was confirmed as solenoidssss. thought he had checked em.
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
