Ok a bit of progress, if all goes to plan the car will be going up to A&T autos in Toowoomba early next week and receiving a Stage Three (full manual, no more ecu bs) transgo shift kit and a 3000~ stall converter...
I'm just trying to get it ready for this drag day, I have to take it down and chop a certain silver maxima lol
got drag slicks? pineappled your dif? tightened up your rear shocks?
your not ready!
your not ready!
Nope (I don't believe anyone will), nope (havent had any diff issues) and er that's just a turn of a knob on the top of my struts
Ok bit of an update, kinda:
*Stage three transgo shift kit has been ordered
*3200 stall to suit my cam has been ordered through the converter shop in brissy
*new tires will be purchased this arvo (only skinny ones as I need them before Monday and no one stocks big ones
*had a talk to Jamie from Forced performance in Toowoomba and confirmed i will be getting a cam package (cam springs pushrods tune) through those guys as soon as the box is finished, ended up going a comp cam 232/234 112lsa lumpy stick and have had the converter built to suit this
*car is booked in for Monday to begin the box overhaul
Also fitted yesterday:
Fitted this afternoon
*new rear tires (just pissy 235s)
*new battery clamp
*new earth cable
*new brake pads
i always thought you were some jerk with a NA skyline,
and then i read this, yes it is a NA but its a LS1 - fair play son
I dont understand how people miss that fact, its written, right there <<<< :P
But yes I wouldn't doubt the fact that I'm still some jerk with an NA skyline (#@t5iv #@Sabbi #@Cadmoon #@olloSKYLINEollo they'll confirm this lol), but yer it's a much more formidable force with the V8 now compared to the old Natro RB.
I'm just glad someone's reading my ramblings
Good luck nick,hope she flys for ya.
Thanks :wub: ... I'm just waiting for the 15th so I can drive it
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
