http://m.youtube.com/#/watch?feature=youtube_gdata_player&v=yEwEv-2cjxk&desktop_uri=%2Fwatch%3Fv%3DyEwEv-2cjxk%26feature%3Dyoutube_gdata_player
Give you an idea of how badly I couldn't get it to hook up, turned tire to almost the 330ft mark on this run *shakes head* :dry:
Can't wait for some sticky rubber :)
Does it have an LSD?
Just a factory one ATM, was talking to Dan about 1.5 ways the other week. In saying that its still turning both wheels even so the old girl must not be to worn yet
yea mang. your gonna get some launch now boy! remember. soften up thos farking coils. and get mother f**king pineapples to twist your diff!
Yep, drag day tomorow will be on street tires again :(
Went 13.71 at 104, I think on the day as the track and car is that's about as fast as I could of went. There might be a bit more in it but just not on this set up.
Probley won't go back untill the new cam and stuff goes in :)
Not a bad time mate. :)
Thanks mate, I'm a little disappointed. I really thought it had a low 13 in it with this set up but apparently not.
In saying that I chopped a 2011 maloo ute by alot of car lengths aswell as an evo and a few other skylines on the day (also lost to an Audi r8 by 0.09 of a second across the line lol). I think alot of people think they're cars are faster "time wise" then what they are, I duno it cut a 13.7 and smashed alot if cars so what does that tell you.
Now.... Cam time :thumbsup:
.... 13.7 for a relatively stock ls1 in a reasonably heavy car is pretty good going. Your 33 is about the same weight as a commo with no interior or fat chicks. Most people have no idea how fast a flat 13 sec 1/4 really is.
N20 time... :yes:
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
