  • 3 weeks later...
In the last week or so I've also managed to go from, this: Ey2MEoa.jpg
To, this: xrQrspF.jpg
Along the way I also discovered the source of my clonking noise, which turned out to be a completely shagged lower left hand control arm.
Lh/LCA: aIv8yP0.jpg
In the next coupe weeks I'm expecting to have that replaced with a new LCA and then I can start fitting up the rear brakes and my new 4.11 2way cusco Diff ;)
4.11 cusco 2 way waiting to go in: e1Ban6n.jpg
Nick are you trying to work out price for insurance purposes?
personally id be going agreed value minimum of 20k.
its a custom car, "paint work" wheels, suspension, engine conversion, mods to conversion.
gotta think about what it will cost you to replace it.
Last one i know of that got sold went for more than 20k, therefore worth more than 20. Typical pom!
my micra is worth 3k.
so i put a turbo and 2-3 grands worth of work into it and its worth 10?
your talking shit matt.
cars worth 5. engine is worth 2-3. labour... no idea.
f**king 20 grand. have a word with yourself.
  • 1 month later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
