Breathing all good?
yea catch can v4 has done the trip
have not had to deploy the scaveng pump just yet
thats pretty good considering 12x12 minute sessions half at 15psi and half at 19psi
Did you throw in a fuel cooler??
yea i did in the end
on the 12 session i had the tank at 1/4 and did a session after 4 laps the secondary pump got noise and the ecu went into linp mode ( fuel pressure protection) so we know that works
restatr car with fuel and all fixed
  • 1 month later...
minor update
been working on these fckers for a while
i want more stopping power
so 996/7 porka cup calipers
380mm full floating rotors(off getting machined)
new brake line, new pads
custom hub adapters and billet dog bones
i was very happy they fit under the 18's
just buy about 7 mm
rally sprint done and dusted
tops fun you guys should get out there
i almost died about 10 times
fastest time got me 10 out of 80
and more importantly beat the only other r33 gtr out there by 9 seconds( although he won a trophy for our class, should have checked they had me in the right class to begin with...lol)
my first ever youtube video check it... after it uploads
http://youtu.be/joAU_gEKMdA
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
