OK I have one group ready to go
Beregron - Are you in NSW?
skyguy3804 - Are you in NSW?
FishinFreak
I'll PM you soon with a snapshot of what the cost is delivered to me in NSW.
P.S. If I can get another 3 people together I'll put another buy together.
Summit racing can have it to your door in 4-8 days for $280
Install is easy in my opinion,but if your not confident with hand tools see if you can get someone to fit it
Jetwreck would be the best option for the east coast boys
I'm west coast so I sorted it myself
How can summit have it you you door for $280? Thats where I just got the quote from.
1 = $310
2 = $294
3 = $288
There's a couple of WA guys that have contacted me before....I'll send your way if you don't mind.
1 = $310
2 = $294
3 = $288
A friend of mine got his for $280 as well :S
I found it under g35 stuff or 350z I think shift kit was $220 us then with shipping and currency was the rest
Off the invoice "trg-re5ro5a-HD2 shift kit" 229.97
yeh thats the one......Scotty's on the case in the background trying to find em cheaper or get em cheaper off my old supplier Mako!
OZ dollar is shit at the moment so its burning.
I bought mine from "Summit" September last year.Cost $276.75 usd.Fro memory ended up about $270 with the then better exchange rate.
Back in the day we used to get em for about $250 delivered....but the current government has pretty much stuffed the Ozzie dollar for a while so no wins. I use to laugh at the idiot on eBay selling them is oz for $650+. I even tried to do a deal with repco at one stage telling them I would take what the had in stock....the best they would do for 20 was $430 aus each and 2 weeks for delivery... I had lolz and told em good luck! 30-40 kits later for the m35/v35/z33 crowd And i still think they have those kits....there loss and shows that there typical Australian retailers.
September last year the doller was 105 cents to the US dollar. Now it's hovering around 90 cents so that 270 becomes 315-320 very quickly
Hey Jetwreck, im in WA, 6025
Footo has mentioned he may be co-coordinating WA buy?
I'll discuss this with Chris again but I did speak to him last night......I thought he was going to do an order directly to WA.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
