Stock Bottom End Rb30Det
kev_31t
 Share
the two ecu's we mentioned shit all over the PFC dejetro in terms of features and performance.
where you from mate?
as long as there not super expensive ill look into it mate as this is just a secondary project haha, im from victoria
find the tuner you are going to use, and ask them what they recommend.
some tuners prefer one ecu to the other.
best to get what they know for better tuning results.
im personally running a haltech platinum pro plug in.
wouldnt go anything else.
I'm not sure about ACL rings but its well known ACL race bearings are a good staple item for building a Nissan.
Personally if the motor is getting rings just spend the money on a set of pistons.. The added compression will make it nicer to drive on the road.
I'm not sure about ACL rings but its well known ACL race bearings are a good staple item for building a Nissan. Personally if the motor is getting rings just spend the money on a set of pistons.. The added compression will make it nicer to drive on the road.
is there any piston options besides forged?? thanks for all the input guys i really appreciate it, i just really wanna do this thing right and get it going reliably
most manufacturers offer non forged pistons for those that just want a standard rebuild.
although, if youre going to the trouble, why not go forged?
if built right, they may have a slight bit more noise when cold, then be fine when warm.
and if/when you mod, theyre already there, to take the punishment.
i understand forged is better but at this stage i just wanna get it going i will build another bottem end and head combo over time, id rather spend the extra cash on a decent computer turbo and fuel system
if you just want it going, id try, and I emphasis try, to find a decent 2nd hand bottom end.
or complete motor.
just a thought.
That was my initial plan too with my RB30 build. Picked up a short block that was advertised to be in great condition. Ran a compression test on it, checked oil pressures everything came out great. Put a 3k rev limit on the ECU and broke it in for 1000 kms. Strapped it on a dyno, pushed it to 5k rpm and the bearings took a dump and jammed the engine. Had to be towed off the dyno back to the shop. After almost 3 months building and anticipation, it just plain sucked. Really don't wish it upon anyone.
We had to take everything apart and redo the whole thing again. Would've been a lot cheaper (and faster) for me to do it right from the beginning and go with Forgies, Race Bearings and a Billet Oil Pump.. lesson learnt for sure. I know many of course that just slapped a stock one and had zero issues.
i cant quite figure out how u guys can be so against throwing a set of decent bearings and new rings, wont starting off with a fresh engine be better than slapping together an engine that i know has excess blowby i just dont get it
 Share
    • I'll chime in here with my experience. Motec is great if you have the money and know a good person to support you. They don't really offer retail support and the dealers make SFA margin on the product, so the business model is setup for you to be supported by a dealer. I'm lucky enough to know a guy who's ex Motec and very generous with his time and is a total boffin. In addition to that, I also use Brad Sherriff who's an absolute legend to work with. The downside to Motec is the software isn't very intuitive, pay to play, poor/limited online support and costly upgrades.  I've not owned an Emtron myself but a good friend runs a performance workshop in Melbourne who is an Emtron dealer. They won't be fitting any more to customer cars because of the poor level of knowledge within the Emtron support team and lack of ability to solve issues with the platform. Not to mention the circumstances around the establishment of the product and company in the first place. I've run Motec's since the old M8's back in the early 2000's so I'm certainly not without a bias but I look at it like this. Everyone acknowledges Motec as the best consumer grade product without spending mega dollars on Bosch Motorsport / Life Racing and so on. When you consider the real cost of your car (not what you tell your mrs) the cost difference between an Emtron and a Motec is tiny, why would you compromise over a few hundred dollars?
    • Closer to getting the shit box back on the road. That long hose, took 2 months to acquire. However the rest were all already to go same week I ordered them. For those playing at home, that long hose is for a RB25DE N/A motor, as they don't run a water/oil heat exchanger, the hoses underneath the plenum are much more elegant and not a maze of shit.
    • One thing you may be able to leverage is the fact that the R34 N/A has the same setup as a S15. The S15 also is a car that gets 350Z diff swapped, so they will also likely have this problem. The caveat of course is it's possible the dash is different between the R34 NA and the S15, but the subframe/sensors/axles/diff setup are the same. I can't remember now as it's been too long, but I don't generally think people need to swap dashes between the N/A dash and the turbo dash when they do things like change the gearbox out, turbo their car, manual swap it, it's just not something I've seen mentioned so this could be compatible.
