I have a 1998 R34 GTT, when I pull the boot release cable the boot lid doesn't spring up by itself. I thought it may have been the boot struts because when you go to close the the boot, the lid kind of just falls so I purchased another second hand set off a guy who showed me on his car that it would open by itself.
Installed the struts on mine, but the boot still wont spring up by itself. Am I missing something? Is there some other spring or something else somewhere.
I just have the stock boot and wing (As far as I know - hasn't opened by itself since I purchased the car)
Thanks for the help.
https://www.sau.com.au/forums/topic/423522-r34-gtt-boot-problem-wont-open/
Usually the boots with wings dont open by them selves. The wing stops this. Boots without wings will fly open. Did the guy you bought the new boot struts from have a wing?
I removed my wing and my boot flys open now.
  • 2 months later...
wow! I've also had this issue since i bought the car about 1.5years ago now. I've been meaning to get it "fixed" as I initially thought it was also the boot struts needing to be re-gased or somethng.
Didn't know it was a "normal" thing that happens.
I've just been opening the boot by using the key. Kind of annoying when you need to take the key out of the ignition just to open up the boot.
Oh well... guess I'll just have to suck it up lol.
On R32's there's a little leaver on the locking mechanism, you slide it up or down which stops the boot lid from unlocking via the in-cabin boot release. This is used in conjunction with your keys, R32's have a normal key and a valet key, the valet key will not unlock the boot or glove box for security purposes.
I assume R34 are similar?
Edited by Missileman
I haven't seen any sliding locking mechanism. Where is it located? on the lever inside the cabin or in the boot itself?
I'm pretty sure I only have 1 key to unlock the car, as well as the boot. Glovebox has no lock on it.
Oh! i do have that. It was covered by boxes so I didn't see it lol.
I moved it both positions, but my boot still won't open from puling the lever inside the cabin. Maybe i do need to replace the struts...
Which position do you move it to in order to make it open from inside?
34 GTT also - same same.
Unlatch only - no lift.
Conclusion - all the same
32 - yep. Had me stumped for a short while when someone changed it in a workshop - WTF ??
But worked it out - lulz had
Remove boot wing and it turns into a catapult - WHOOSH !
Edited by Sinista32
Don't the 34's come stock with a wing? If so, then why would they make it so that it doesn't open with one? lol. :verymad::/:down:
Nah sorry - not the 34. It just seems to be a design fail.
But the 32 does come up slightly with the stock wing. Different hinge mechanism.
When you remove the wing from a 32 it slams up !!
I haven't removed my 34 wing to test, although due to wheight reduction, I would expect it to come up higher.
Quite often on my 34 it will latch itself again :(
yep, my r32 was the same with the spoiler removed, refitted spoiler and now i just use it as a handle to open the boot
haha, that's what i do.
Mine unlatches and latches back straight away. Have to just keep using the key i guess :down:
    • This is awesome.
    • Thanks for the quick replies guys its appreciated. A small extension was welded onto the standard 6boost external gate pipe which you can see where the pipe goes from black to stainless just below and to the right of the rear housing in the first picture. Overall I would say the flow is pretty good other than 6boosts choice to come straight off the collector at a decent angle.. Not sure why I went with two valves, I originally replaced the stock twin bovs with the GFB when I had the twins on. When I purchased the EFR it came with the Turbosmart Kompact BOV so I figured that would be a better option than the stock EFR Bov. I don't believe the Turbosmart BOV is adjustable? When I get the spike and then sudden dip in boost pressure, the turbo speed does drop as well. Stock head size wise however I believe it has Neo Turbo springs and a Neo Turbo intake camshaft and an aftermarket exhaust camshaft in the vicinity of 260 degrees. We didn't try a different MAC valve, we tried two different ways of plumbing it and we also tried removing the mac valve entirely and just having the boost source from the turbo directly connected to the wastegate and it still spiked / dropped and exhibited the same behaviour. Standard R33 GTR 5 speed tansmission. I'm running a Haltech Elite 2500 and can provide some logs if you. I understand what you're saying in that it looks like an auto plot however no, it's still a manual and it just has a lot of torque down low, for all intents and purposes it's a very impressive street car. I've attached a photo of the quickbitz dyno plot which was when the only difference is I was running -5 twin turbos with a mac valve. As you can see theres a decent dip in AFRs between 125kmh and 135kmh. Our problem now is not that the AFRs are dropping, just the boost pressure is dropping, however it is evident in the same RPM range of the map, coincidentally or not.
    • What transmission are you running?  It's a bit tricky with the scaling, but at face value the power "curve" looks more like a "line" which is a bit odd... basically a lot more like a dyno plot I'd expect with a highish (compared to a factory auto) stall torque converter type setup. If this is running an auto then this kind of boost control challenge is definitely a thing, the rpm scale on the dyno doesn't reflect what the engine is actually doing (unless the dyno has access to the engine's ACTUAL speed electronically) and what you'll get is a big rpm flare up as the engine torque launches past the converter pump's ability to resist torque at that rpm, then as the converter starts picking up rpm it will kinda even out again and the engine rpm will pick up more steadily. The trick with this "flare up" is if it's kinda near the boost threshold for the turbo then the engine's airflow requirements to maintain the previous boost level will outrun the turbo's ability to supply that boost - so you end up with a natural flattening off, if not dip when that happens.   If you are running closed loop, or even tune the "feed forward" wastegate duty cycle to deal with that rpm spike then when the engine starts settling to a more typical climb you'll actually have a situation where the gate is "too closed" and boost will run away for a bit, then have to pull down again.      It's not trivial to get this perfect as most boost control systems are generally expecting more predictable engine rpm rates of change, but if you *know* that's whats going on then you can at least "accept your fate" and realise getting that area perfect is kinda chasing your tail a bit, and assume that if the rest is working sensibly and the spike/dip isn't completely uncontrolled then you should be good. Sorry if I've gone off on a tangent, but the dyno plot and boost control behaviour look a LOT like what I've seen tuning autos in the past. What ECU are you running? Could possibly be convinced into looking at logs if I get too bored this weekend haha.
    • A few things that seem a bit off here. - why is there 2 BOV’s?  - the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things. - stock head? Does that include springs? - tried a different MAC valve? Is it plumbed correctly?
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
