Deca Accommodation - Fri 31 May & Sat 1 June 2013
Where: Courtyard Motor Inn
Address: 58 - 60 Wyndham St, Shepparton VIC 3630
When: Fri 31 May & Sat 1 June
I've reserved the entire hotel.
You need to let me know ASAP which room you would like booked.
Dinner TBA
Rooms Left:-
Executive w/Cnr SPA $120
Queen $90 - 1 ROOM
(as always - priority goes to people staying both nights, unless I can do a clean swap)
If this hotel books out, I've got 2 other options directly across the road for extras as well!!!
http://wyndhamere.bestwestern.com.au/
03 5821 3088
OR
http://tudorhousemotorinn.com.au/
(03) 5821 8411
Accommodation List:
FRI & SAT nights
Bec - Queen (plus Thurs)
Ryan - Queen (plus Thurs)
Leon, Hayley & Flynn - 2 B/r (plus Thurs)
Campbell & Laura - Queen SPA (plus Thurs)
Paul & Kat - Queen SPA (plus Thurs)
Russ & Femno - QU + sngl
Mark & Trent - QU + sngl
Wayne - Queen SPA (plus Thurs)
Simon - Queen
Leroy Peterson + 1 - QU + sngl
Daniel (NSW) - Queen SPA
Shane & Megan - Queen SPA (plus Thurs)
Juliette - Queen SPA
Kieran & Brad - QU + sngl (plus Thurs)
Chris Taylor - Family (Qu + 2 sngls)
Chris Taylor - Family (Qu + Bunks)
Jett - QU + sngl
Tim Watson - QU + sngl
Jarrod & Mel - Queen
Darren & Tony - Qu + sngl
Paul & wife - Queen SPA
FRIDAY only
Michael (XR8TD) - Queen SPA
Jake - Queen
SATURDAY only
Darren Lang - Queen
Friday night + Saturday night
Single Room (1 x Queen bed)
Please make sure there's a bible in the desk drawer and plenty of lube in the bathroom.
Your gonna need heaps of lube if you have any chance of fitting that bible in your ass..
I bet he will still manage it though
Can you put me down for a queen, Fri + Sat nights pl0x becskies
DDDEEECCCAAA!!!! DDDRRRIIINNNKKKIIINNNGGG!!!
Dinner TBA
Rooms Left:-
Queen SPA $95 - 4 ROOMS
Not sure what my room is but I may as well go with a queen + spa $95 if it isnt already
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
