1996 R33 Skyline GTS25T Series 2, only done 147,000kms Black in color.
Serviced regularly with hi grade oil. The car has never had any mechanical issues. Neat and clean apart from the front bar and bonnet (more details below).
Whats Stock?
Stock Turbo, running 12psi actuator, approximate power 180rwkw
Stock ECU
Stock SMIC (have FMIC to suit however pulled it off for RWC)
Stock BOV
Whats Not?
Super big brakes on the front. 330mm Ksport 8 pot calipers with Bluestuff Pads
Quiet Sleeper JDM catback exhaust.
17" Matt Black Rota Rims 9 inch wide with 255mm wide Advan Neova tyres (super grippy) These are $400 per corner for tyres alone.
Immobilizer and alarm (central locking needs new actuators but wiring is there)
Apexi style pod filter
Turbo timer
HICAS lock bar
Unknown Clutch, but grabs brilliantly
Tein Super Street Adjustable shocks and springs.
Pioneer cd player
Rear Strut Brace
Front Strut Brace
Have new tie rod ends to install
Ok, now to the front bar and bonnet. I had an argument with a pole a while ago and wrecked the front bar and dented the very front of the bonnet. I replaced the front bar with a silver one. Check out the photos. The front bar will need a respray and either dint removed from the bonnet or a new bonnet. (Can supply a white bonnet to get resprayed if that's what you want to do). The respray should cost between $500 to $800 depending on how friendly you are with the s
pray painters. I've been driving as it is for a year and a half, completely non structural.
Comes without RWC and plates unless the right deal is struck.
Viewing at 3199
Asking $7,800
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
