hey all, i bought my r32 with one of the bearings destroy(metal pieces everywhere) which in turn rendered the box useless, i had another rb20 box installed $750 all up.
But now im seeing that this new box has a small whine nothing too bad, but today was the first i actually gave it in 1-2-3 gear, and when it into 2nd it went in like it was going explode if i did it a few more times. Are all 20 box's like this, or is this box probably stuffed aswell?
thanks
https://www.sau.com.au/forums/topic/423987-rb20-horrible-gearbox/
It feels so bad when going into 2nd quickly, im not snapping it in but just fast, feels like its not far from crunching, the box just feel weak. Im curious if this is like all the 20 boxes.
Edited by HungarySkyline
wrong.
Its the same box as whats in most of the 5 speed RWD cars, except R33 GTST and Z32 twin turbo IIRC.
It shouldnt feel like that, if anything it should feel better than an RB25 box on quick shifts. Lighter gearsets and components would make it easier to change between cogs.
That box has a problem. I can shift like an absolute MOFO in my S14 (and every other 5 speeder I've driven) and it is the same box. It could be the clutch, but you should take it back to the mechanic and get them to sort it out.
And R34 GTT.
All the 20 boxes I have driven with (4 from memory) have felt extremely fragile in comparison to the 25 box. That said, Scott knows more about these things than me. Best get it checked out.
Yeap, I wasn't sure about the GTT as I know it comes 6 speed lol couldnt recall if there was a 5 speed model also, but am sure they would use the same box as the 33.
The smaller 5 speed is definitely pretty fragile in comparison, but shouldn't feel like its going to explode. Should just feel lighter to work with than the bigger boxes, and like I said should shift easier/quicker with less effort.
If i were you id be diluting the gearbox oil with some engine oil, thats what i did and my box went from crunching, jarring and needing a rebuild to now being smooth and awesome :yes:
If the oils too thick or its overfilled it will not help.
Edited by AngryRBGTX
Fwiw certain trucks use the same oil for the box as they do for the motor (5w30) so the motor oil suggestion isn't a bad thing and can help.
Personally I would take it back. You paid good money and got a shit gearbox.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
