Risking- couldn't agree with you more. I'm building a JZA80 Abflug and it's an aero.
We bought a Cusco bolt in cage and F*** me was it shit.
I looked at the sandwich plate design to the floor pan and laughed.
Ended up chopping it all up, completely redesigning it, added bolt in side intrusion bars and made the hole thing completely bolt it.
Now it'll actually do its job both safety and rigidity.
I'm surprised these cages are designed so close to the occupants. I spose it's the easiest way.
Just a quick update.
Brad has messaged me this morning to confirm he's received my messages and has ensured my order will be filled.
He also noted I am the only person who's emailed him, as that's his referred method at the moment so keep that in mind.
There has been alot of things going on with the workshop recently and there has been some delays guys that I'm apologetic about.
There has also been some massive changes made to retify what's been going on which is personal and won't be shared freely.
I've been contacted by dan and a couple of others now via email and I appreciate the contact through that channel which is greatly preferred at this time.
I must stress through the only email to contact me via is [email protected]
The work quality I refuse to let slip away which is why the delays have occurred. With the time I've been putting into some other things some jobs have taken a bit of time to complete to the high standard I hold myself to and all I can do is apologise for that.
Is rather be know at this time to be slow and have good work that be fast and produce rubbish quality which I feel would tarnish my reputation more than a time frame issue.
Personal issues is an understatement at the moment.
The two cages you guys ordered are complete (photos have been seen) getting them sent off at a reasonable cost (considering I did free freight) and trying to get it into my spare time atm has been difficult.
Next week is a new week and will see them in your hands.
We're now into the second week after you mentioned the above.
Can we get a con number please, I'm happy with a refund also if you'd prefer. If so, let me know and I'll PM you my bank details.
Sent to your email also.
Edited by ActionDan
My cages have been sent, whether that's because I was fairly persistent in my nagging or because Brad has sorted things out and is clearing up a back log of work is not known to me, I'll be glad to get my hands on it though, put it in the car, and get my ass track side.
Edited by ActionDan
  • 7 months later...
Here's some pics.
You can see what's needed to install the main hoop.
A plate is welded to the floor pan that has captive nuts on the back (you must drill holes for them to recess into). You then bolt the cage to the welded floor plates. The back stays are just bolted in like a normal bolt in cage.
The cage itself seems quite decent and a few people commented on it being a fully welded design, getting it in the car was not that hard - with a ratchet strap to compress the main hoop a little for clearance.
All in all it seems decent, though I wonder if I should have just put a full cage in it and been done with it... ?
The experience of obtaining it has mentally scarred me :)
Edited by ActionDan
The AGI was a slip joint, bolt together for more money than this cost as I chatted with them also.
That said, many have said the experience is good with them.
Oh as for washers, didn't come with any and while you might get some on the front two holes, you'd be hard pressed to get anything useful on the back.
Edited by ActionDan
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
