Hi all,
As post states my beloved R33 1995 GTS-T has been stolen from the front of my house in Fawkner. Pricks took it between 1-7 am I can't believe I didnt hear anything. Details of the car are as follows:
White 1995 R33 GTST coupe
17 inch P1 buddy clubs bronze colour
gtr front bar with bog patches on it, in the middle of being repaired. fmic
no spoiler, has duck wing on it.
sideskirts, right hand side skirt has sticker on it "tuned by dr drift"
tinted windows
car does stand out so again if spotted PLEASE post, contact police or me.
If anyone sees it around please contact Fawkner police 9355-6000 and ask for Const. Atherns or contact me via pm.
thanks guys.
https://www.sau.com.au/forums/topic/425150-r33-gts-t-stolen/
Hope you find it mate, mine was stolen about 6 weeks ago too, seems to be getting just worse an worse.
I'll keep my eye on drift sales and the like, a guy was attempting to sell a stolen car on there a couple of weeks ago so you never know.
Just over an hour after posting that we are now sitting on 1,242 people having seen that post. The more eyes out there keeping a look out, the better the chances somebody may spot it :)
Not sure about the other page, but no doubt a couple of thousand views from there as well.
Hope you get it back very soon!
First post mate, but I'm from the area and will keep an eye out for you. An often asked question, but did it have an alarm/immobilizer? I'd be interested in comparing the amount of thefts of these vehicles which don't have an alarm to those which do. It's dizzying the rate at which these cars are stolen.
Best of luck.
Colourclassic: Thanks mate we would appreciate it if you kept your eyes peeled :) Yeah it did have an immobilizer but installed years ago when I first got the car. So nothing flash oh and the steering wheel was locked which doesn't mean shit really as they can break that very easily too. But at the end of the day no amount of protection other than gps I think really safe guards you. If a pro wants your car I think unfortunately they win regardless :( I wish I could of caught them Id feed their balls to the dogs!
We've put it up on the Facebook page for you, fingers crossed you get it back soon!
Edit: Got it onto the Stolen Imports Australia page. Everybody will keep an eye out now :)
Will be adding this page! Thanks...... OP Sorry to hear, will be doing NSW to VIC trip in a week or so, will also keep eyes peeled!
Thanks 34gtt, remember rewards offered !
No reward needed for fellow SAU members :) Just hope you get your pride and joy back! I would be lost if it happened too me! Have you got any better pics of it to help?
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
