Hey guys, im sure this has been covered a hundred times before, but im looking at upgrading my turbo and am looking for around 300kw at the rears. I have an pfc, z32 afm and 550 or 600cc injectors (not sure, bought them off a mate and he cant remember) and a walbro intank all waiting to go on. I want sumhing with good response, but a little bit of lag doesnt worry me. I have a ffp (fitted) and high mount manifold also, so external gate is fine. And i will be getting it tuned after the turbo amd everything else is fitted. All proper help would be greatly appreciated!
https://www.sau.com.au/forums/topic/425377-time-for-a-new-turbo/
Check out Hypergear (on this forum). I have an ATR43G3 that has been dyno tested to over 300rwkw, however i think they have made more responsive turbos with greater power potential since i bought mine.
Otherwise Garret 3076r seems to be a popular choice as well
Finding information about turbos for a newb is very hard.
With so many turbos on the market and most of them with the same generic ID it's really hard to find information.
If people started to post the name of the manufacturer and turbo ID, life would be easier and you wouldn't have so many turbo threads.
Also we need boost and nm torque dyno sheets, kw's mean nothing without the other supporting information that tells you how it will drive.
the hypergear atr43g2.5 has 50nm & 20kw & 2psi more than the hypergear atr43g3 at 3000rpm
Or is the way i read dyno graphs wrong?
I assume you are just looking for some thing bolton to stock manifold and dump. If that is the case you can run our latest SS2 and G3 RB25 dump internally gated units. The 98 graphs from our site are old, Unfortunately all of our latest turbos and ideas was tested on E85. So best to check out the E85 results, and take 40kws off top to estimate 98 result.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
