R.3.2.G.T.R Posted May 23, 2013 Share Posted May 23, 2013 hi peeps, need some help sorting out my rear end on my 32R, can feel rear wiggling from side to side at around 60-70kms, on smooth road, no tramlining etc, worse in the wet few things done recently: all hicas bits removed completely and fitted with driftwork elimination kit wheel alignment done at jax blacktown - rear toe at 0mm both sides now before the hicas mods, this wasnt an issue, was running approx same camber at rear, not sure on toe i have subframe collars and not installed yet, could existing ones cause the issue? anything else i should be checking in the meantime tonight i will be double checking the wheel shake and coilovers (tein current set to middle of range) and all bolts in the vicinity tyres are month old, same all round and had wheel balanced when fitted, car is legal height and street driven anything wrong on my alignment sheet? 1 Link to comment https://www.sau.com.au/forums/topic/425737-wiggling-rear-end/ Share on other sites More sharing options...
Sinista32 Posted May 23, 2013 Share Posted May 23, 2013 (edited) I'll check mine when I get home. I don't see anything jumping off the page. Sounds silly but have you double checked wheel nuts ? - track difference and thrust angle stick in my mind for some reason but will check Camber is the exact same front and rear ??? Did you ask for 0 toe ? Edited May 23, 2013 by Sinista32 Link to comment https://www.sau.com.au/forums/topic/425737-wiggling-rear-end/#findComment-6862316 Share on other sites More sharing options...
R.3.2.G.T.R Posted May 23, 2013 Author Share Posted May 23, 2013 I'll check mine when I get home. I don't see anything jumping off the page. Sounds silly but have you double checked wheel nuts ? - track difference and thrust angle stick in my mind for some reason but will check Camber is the exact same front and rear ??? Did you ask for 0 toe ? wheels nuts torqued camber front and rear is identical but i didnt ask for that, running 18x10+15 rims so cambered as little as i could for it to lineup with the guards rear toe i asked for 0mm thinking it was better and didnt want it to contribute further to already cambered rear tyre wear Link to comment https://www.sau.com.au/forums/topic/425737-wiggling-rear-end/#findComment-6862334 Share on other sites More sharing options...
gtr jet Posted May 23, 2013 Share Posted May 23, 2013 I had a similar issue and fitting rear sub frame collars fixed it for me. Link to comment https://www.sau.com.au/forums/topic/425737-wiggling-rear-end/#findComment-6862357 Share on other sites More sharing options...
darksky34 Posted May 23, 2013 Share Posted May 23, 2013 could be any number of things, but i think i had similar with my car (with known issues), before i put in: hicas lock bar new tie rods (rear) new shocks (had a leak in one) sway bars pineapples (subframe alignment kit???) before all that, car would sometimes feel like it wobbled on a turn, or over a small bump. now all gone. Link to comment https://www.sau.com.au/forums/topic/425737-wiggling-rear-end/#findComment-6862365 Share on other sites More sharing options...
GTSBoy Posted May 23, 2013 Share Posted May 23, 2013 The quick and dirty test/check is to get the rear toe set to -1mm and see if that makes it feel better. With 0 toe your wheels actually end up toed out while driving because the dynamic forces transmitted from the road push the wheel backward relative to the car and that causes it to swing around the upper and lower inner suspenion mounts - basically twisting the bushes. The upper tension arms only do a certain amount to prevent that because they are on an angle themselves. Toe out causes the wanders, so dialling it out is an easy check. Other than that I would say you need to look for; *Sloppy tie rod ends from the HICAS, assuming that you still have them there (and most HICAS eliminators do leave them there). *Sloppy bushes in any and all of the suspension arms. *Tired subframe bushes. Collars will help, but brand new ones are a serious improvement. It's a lot of work to change them, but worth it. Link to comment https://www.sau.com.au/forums/topic/425737-wiggling-rear-end/#findComment-6862539 Share on other sites More sharing options...
R.3.2.G.T.R Posted May 23, 2013 Author Share Posted May 23, 2013 thanks for the replies guys no tie rod ends left and will check all arms tonights, coilover isnt leaking otherwise ill slap on the c-collars over the weekend and have it adjusted to -1mm on each side as suggested i have whiteline rear swaybar installed with new link bushes etc, that was done a while back will report back tonight after checking Link to comment https://www.sau.com.au/forums/topic/425737-wiggling-rear-end/#findComment-6862561 Share on other sites More sharing options...
Sinista32 Posted May 23, 2013 Share Posted May 23, 2013 (edited) As said by GTSboy - Start with adding rear toe. I'm on the street most of the time and handles very well. Dialled in to handle well for the street and reduce tyre wear (so a compromise) At least for mine, so you can compare. (and I trust my guy) Toe on the front - Half toe +1.5 degree (total +3) Toe on the rear +2 degree's - Will straighten up when driving. Plus I really don't like tracking. I also run more caster on the left than the right (opposite to yours) Neg camber on the front -2 (slightly more on left than right) Neg camber on the rear -1.5 (slightly more on left than right) Track difference of 0.07 RIms - 18x9.5 +12 Mine is also different on the king pin angle and thrust angle. Adjusted so it doesn't dart to one side under Hard acceleration. Edit: think they added more camber to the rear (+2) last time but I didn't get a printout Edited May 23, 2013 by Sinista32 Link to comment https://www.sau.com.au/forums/topic/425737-wiggling-rear-end/#findComment-6862613 Share on other sites More sharing options...
Duncan Posted May 23, 2013 Share Posted May 23, 2013 Your alignment is fine, might be a little taily on the track but that can be fun (personal preference). Plus, alignment would only create instability at the rear if there was a lot of toe out. So, I reckon there is a problem in the toe control. Start at the centre and make sure the lock bar is bolted down securely, then check the inner tie rod ends are tight. But I reckon it's almost certainly stuffed ball joints at the outer/hub end of the tie rods. That was the issue I had, and I had exactly the same "tail wagging" feeling. Unfortunately they are both painful and expensive to replace, I could not find an aftermarket option Link to comment https://www.sau.com.au/forums/topic/425737-wiggling-rear-end/#findComment-6862789 Share on other sites More sharing options...
R.3.2.G.T.R Posted May 23, 2013 Author Share Posted May 23, 2013 Your alignment is fine, might be a little taily on the track but that can be fun (personal preference). Plus, alignment would only create instability at the rear if there was a lot of toe out. So, I reckon there is a problem in the toe control. Start at the centre and make sure the lock bar is bolted down securely, then check the inner tie rod ends are tight. But I reckon it's almost certainly stuffed ball joints at the outer/hub end of the tie rods. That was the issue I had, and I had exactly the same "tail wagging" feeling. Unfortunately they are both painful and expensive to replace, I could not find an aftermarket option thanks Duncan, I believe u have nailed down the issue, re-checked all bolts and tried to see if any bushes are worn and leaky without much luck What I did find is that one of the elimination kit brackets is not bolted "square on" like the other side, although not loose might under load be moving from not being aligned squarely I'll fit the subframe collars and set n torque the bracket correctly on the wknd before alignment with specs listed earlier One thing I don't get as kit came without instructions is, other than the bracket bolt being done very tightly, what will stop the bracket from tilting from load, better pic of one side below Link to comment https://www.sau.com.au/forums/topic/425737-wiggling-rear-end/#findComment-6863084 Share on other sites More sharing options...
Duncan Posted May 23, 2013 Share Posted May 23, 2013 ahh interesting, I hadn't seen that style of lock kit before. It's very similar in concept to the factory non-hicas setup on the stagea. I am not excited about the design of the brackets because they have a single bolt, and no apparent locating dowel or flanges against a locked surface. In any case, if a bracket with a bolt that big is moving it will not be a smooth "wiggle" but rather a sharp/clunk unless it is finger loose. also you would see scraping on the paint of the subframe if it was moving. given the inner and outer rod ends are bearings and new they should be easy to check for slack. is the outer end now a bush of some sort instead of the factory ball joint? If so, it might be the whole subframe that is shifting relative to the car? Link to comment https://www.sau.com.au/forums/topic/425737-wiggling-rear-end/#findComment-6863285 Share on other sites More sharing options...
R.3.2.G.T.R Posted May 23, 2013 Author Share Posted May 23, 2013 yeah i couldnt find any info on how the bracket is located other than the single bolt and looking at other ppl's install pics, it appears to be the same no paint or wear marks on the bracket and its still relatively tight the outer end is now bush replacing the factory ball joint, i also checked both wheels for any movement but it was solid, its odd that only now the subframe is shifting or perhaps it was happening previoulsy but not felt due to worn ball joints is lowering subframe just a matter of raising the car to a suitable height with the wheels sitting on something and undoing the bolts in front and back till the end of the thread? Link to comment https://www.sau.com.au/forums/topic/425737-wiggling-rear-end/#findComment-6863360 Share on other sites More sharing options...
Duncan Posted May 24, 2013 Share Posted May 24, 2013 I guess that could work....but I've always put the car up on stands and then put a jack under the centre off the diff (good balance required). Nuts off, or right down to the bottom of the thread, and then lower it on the jack Link to comment https://www.sau.com.au/forums/topic/425737-wiggling-rear-end/#findComment-6864493 Share on other sites More sharing options...
luke gtr Posted May 25, 2013 Share Posted May 25, 2013 Your alignment is fine, might be a little taily on the track but that can be fun (personal preference). Plus, alignment would only create instability at the rear if there was a lot of toe out. So, I reckon there is a problem in the toe control. Start at the centre and make sure the lock bar is bolted down securely, then check the inner tie rod ends are tight. But I reckon it's almost certainly stuffed ball joints at the outer/hub end of the tie rods. That was the issue I had, and I had exactly the same "tail wagging" feeling. Unfortunately they are both painful and expensive to replace, I could not find an aftermarket option werent as bad as I thought they be, price or difficulty to replace. Link to comment https://www.sau.com.au/forums/topic/425737-wiggling-rear-end/#findComment-6865319 Share on other sites More sharing options...
R.3.2.G.T.R Posted May 27, 2013 Author Share Posted May 27, 2013 alright, c-collars installed and every bolt that i could get to tightened up with torque wrench, will try and squeeze in an alignment tmrw lunch-time, hopefully last one for a while and it fixes the wiggle Link to comment https://www.sau.com.au/forums/topic/425737-wiggling-rear-end/#findComment-6866784 Share on other sites More sharing options...
R.3.2.G.T.R Posted May 28, 2013 Author Share Posted May 28, 2013 As said by GTSboy - Start with adding rear toe. I'm on the street most of the time and handles very well. Dialled in to handle well for the street and reduce tyre wear (so a compromise) At least for mine, so you can compare. (and I trust my guy) Toe on the front - Half toe +1.5 degree (total +3) Toe on the rear +2 degree's - Will straighten up when driving. Plus I really don't like tracking. I also run more caster on the left than the right (opposite to yours) Neg camber on the front -2 (slightly more on left than right) Neg camber on the rear -1.5 (slightly more on left than right) Track difference of 0.07 RIms - 18x9.5 +12 Mine is also different on the king pin angle and thrust angle. Adjusted so it doesn't dart to one side under Hard acceleration. Edit: think they added more camber to the rear (+2) last time but I didn't get a printout was that 2deg rear on each side or total? Link to comment https://www.sau.com.au/forums/topic/425737-wiggling-rear-end/#findComment-6868437 Share on other sites More sharing options...
Sinista32 Posted May 28, 2013 Share Posted May 28, 2013 (edited) Each side. Works for me Neg camber on the rear -1.5 Toe +2 Edit: Although as some one above said you shouldn't have an issue with the settings you originally posted. Your camber settings will save just a little additional wear on the tyre inside. Which is normally fine for normal street driving. More camber on the front for turning and less on the back as it will follow and does not "turn". I would only suggest you reverse your caster settings up front as it will help stop drifting towards the gutter. General rule is as much caster as you can get without scrubbing and more on the left than right. Edited May 28, 2013 by Sinista32 Link to comment https://www.sau.com.au/forums/topic/425737-wiggling-rear-end/#findComment-6868997 Share on other sites More sharing options...
Sinista32 Posted June 3, 2013 Share Posted June 3, 2013 Have you identified and rectified the issue causing the Wiggling rear end ? Link to comment https://www.sau.com.au/forums/topic/425737-wiggling-rear-end/#findComment-6876168 Share on other sites More sharing options...
R.3.2.G.T.R Posted June 4, 2013 Author Share Posted June 4, 2013 yeah got an alignment over the wknd, rear feels heaps more stable i re-adjusted the brackets to be more square and torqued it, something i didnt do initially also the rear diff bracket/support bar was a lil loose on one side, ended up checking all bolts that i could get to there was one stretch of road which previously amplified the wiggle, much much better on that stretch now Link to comment https://www.sau.com.au/forums/topic/425737-wiggling-rear-end/#findComment-6877178 Share on other sites More sharing options...
