Never heard of horror stories with this, so long as its used for its proper purpose.
Not for AFM filament I don't think.
It's so powerfully effective, it's been known to take grime off wheels that nothing else could remove.
It was always used at every service on my Subie Foz XT down the piping. Recommend!
If you read the directions on the can, it stipulates to spray half of the contents into the inlet manifold while the motor is off and to wait 10-15mins before starting so it can do it's thing. Then, when it eventually starts, it will take some cranking to get it going, speed the motor up to 2000-2500rpm and spray the rest of the contents on and off letting the motor breath. The revs will drop as the nozzle on the can is depressed.
Any Success/Horror stories?
Lawwwwllz. Yes.
I was spraying the straw into one of the ports on the plenum and the vacuum sucked the straw right off and right into the runners.
After trying madly to get it out with a grabber tool, I only ended pushing it further in.
I eventually gave up and ran it through the engine.
That was a few years back and I never think it did any damage.
Moral of the story: attach some thin pvc tube or similar to the nozzle. That way you can always keep the can upright, and the straw wont get sucked through the tube.
Good shart, but beware, if you leave it for too lone it will start to eat gaskets and goos. Also, don't use on rb26's per throttle body as it eats the thin film of silicon that seals the butterflies. You have been warned.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
