I had cam gears too, forgot to mention on the mod list.
Was planning on injectors, pump, Nismo AFM's and EBC to milk out as much power as I dared, that never happened (binned the car @ DECA few months later).
Feck, I miss that car.
Ahh well that explains the mid range difference!
350rwkw should be quite achievable on these setups with E85.
Seen -9's go 350rwkw on 98 with a built engine. The one in NSW, Nick I think his name is? Would be interesting to see his on E85!
Buy another one :P
Buy another one :P
Yeah, would like to buy another one even though I've bought 3x GTR's after this one... :unsure:
Know of 350rwkw -9s set up, yeah Nick aka Levinboy. I'm sure you've seen a E85 result of 370rwkw - forgot the blokes name.
That would be usmair, his mph didn't back up the power figure though but apparently he was having some problems.
Haven't heard anything about him going back to the drags or jumping on another dyno to confirm power figure.
Another e85 result that surprises me is Nathan's which is also on Trent's dyno. 379rwkw, -7 and e85.
Even my mate Grech's result is 36xrwkw, -7, e85 on Racepace's dyno.
Would be interesting to see more e85 results with these small turbo setups to get some comparisons
Hey Micheal,
Any GTR with -9's pushing 350rwkw is already plenty. Once you start to go over that those turbs tend to run out of efficiency.
I would be happy with just 350rwkw with lots of of response rather than more poahwa and more lag.
having said that I cant really talk. Cause I have opted for -5 :wacko:
I heard my name wassssup haha
Like ants said I'm getting to the end of the efficiency range of the -9s
Next year maybe will go full flex setup but quite happy with the way the car is on 98
As the car is my daily ;)
Hey Micheal,
Anth, my thoughts exactly. If it makes more then great, but 350kw peak power would be plenty enough.
If I can get say 220kw by 4000rpm, and 300kw by 5000rpm, that would be ideal.
Are you going to use e85 Anth?
Can't wait to see the results of yours being tuned!
Haha! SAU famous!
Yeah, flex fuel would be best if it were a daily. I'm just lucky to still be driving my old bomb so can justify going on E85.
And that way I never have to sacrifice the power :P
Hey mate, nice build! Car looks lovely :)
Just completed the fuel pump rewire a couple of days ago
How's this wiring setup held out so far? Any leaks through the connector or did you seal it up with epoxy or something similar?
Cheers :)
There's no opportunity for leaks as the wiring you see in the 2nd pic connects to two terminals on the lid and there's another plug underneath. Some people change to the thicker cable
all the way down to the fuel pump but I've not heard of any issues with people using this method and I haven't had any thus far.
Hi mate,
Yes, I will be going E85 but not for run-in tune. We will go E85 after that for full poahwa tune ;)
Have a look at my build thread - some dyno footage is already is up.
  • 11 months later...
So, been a while since last update.
Car has seen some changes.
Xspurt 1000cc injectors, Nismo AFMs, PFC, advanced the intake cam, E85 and some more boost.
As a result, 363kw peak power and 597Nm peak torque.
Blue line = 21psi on E85
Pink line = 18psi on E85
Red & Green line = 18psi on 98
Very happy with the gains particularly at 4000rpm.
One thing though, water pump bearing gave way on the last run due to me getting a little bit too excited on the alternator belt tension when removing timing cover.
Water pump is on the way, so hopefully will have the whale back in action next week.
  • Like 1
Sensational results Mike
Great to see updates
Also glad to see you are willing to use the car on track :thumbsup:
Cheers Anth, glad to see you jumping on the E85 wagon too! You'll be joining the 400kw club I guess!
don't fancy the idea of high oil temps though. Use Edge 10w60 but still gets pretty warm on the factory gauge (around halfway - not so sure what that is, but I guess 120?) when going through the hills
So, was speaking to my mate with a 33 gtr as well and his words were that the line just before 150 thats not marked with a temperature is approx 120deg on the factory gauge.
Could someone confirm this? Because I've been thinking halfway is around 120 this whole time and backing off.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
