i run a NPC single 10" carbotic in a 400 rwkw rb26/30 powered drift car.. it loves it. Clutch has been going for near 3 years now, took it out not long ago and it had only worn 5% of the material off... so well and truly still serviceable!
wowowo
thankyou.....
  • Replies 45
Another happy NPC customer here. Not running as much power as some others but im really happy with mine. Sounds like the same as what they offered you. Hasnt missed a beat in 3 years I think ive had it. Getting it rebuilt soon purely because the gearbox will be out unless it still has plenty of meat
Lash out and get the NPC flywheel if you have the money to. Its a good product and saves 3-4kg from memory
^ with the carbotic, I found it harder to drive than a 4 Puk Exedy ceramic clutch, but once you get used to it, it's fine.. just avoid hills lol.. I usually bake tyres starting off on steep hills.
However, I have driven an EVO with a NPC Organic, it's quite pleasant to drive.
ok thanks - what do you mean harder to drive? when releasing clutch where it engages? is that what ppl mean (taking off from a stop) if this is what it means i feel like an itdiot lol
Taking off can be rough. It cant be ridden or else the it causes shuddering so you gotta push the rpm up. 3 years is awesome life span. How many km have you guys done in that time? Up hill in rain is terrible. In actual fact I avoid big up hills when its raining, mostly and especially car park ramps. Make sure you do bed the clutch in properly.
I used a 5puk for a week and then removed it, in traffic it was terrible, my gearbox and driveline felt like it was getting raped..
Unless your car see's ALOT of track work then don't bother.. :unsure:
Keep in mind, the organic will take a good beating but I would imagine that the heat will get to it after prolonged abuse, so maybe a lightened flywheel with cooling slots would be a compromise, but that's another subject. I vote for NPC organic.. done.. :yes:
yeah i guess it is hard to pick as i might drive it to work once a week low traffic and or once or twice week jsut cruising round - reset will be on the track -
i think this clutch will be a good starting point for me as things might change and car may end up 90% track/ drift so to start off will see how this goes
when you guys have replaced ya clutch and seals - where are you getting your seals ? basic nissan seal or an aftermarket seal?
Nissan, do not get ling long..
eBay US is a good place to find them OR kudosmotorsports is good too.. (a little pricey, but good service and speed)
With the NPC carbotic, do you guys gently ease the clutch in when taking off, or just dump it with a few thousand rpm (like i do)? I heard these clutches CANNOT be slipped at all.
The carbotic can be driven like most clutches, if you are gentle you get a slight shudder and if you a harsh you get skids :woot:
Genuine Nissan! Wasnt that bad from memory!
ive had npc bigmouth 10" clutch for 3yrs now bought in sep 2010, 3 test n tunes, 5 powercruises and its still going.. power has been around 400-480rwhp mostly thru out the 3yrs
Bigmouth? :P hehe....... My Jim Berry has done 2 powercruises and mainly street duties BUT i love it!
Good to know, i went with the NPC 10" Carbotic pull- type for the GTT, was expensive (god damnit pull type!) but it should last me a fair while. When bedding it in should i slip it, dump it or a half/half situation?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
