Hi guys,
My r32 Gtr is on dyno and has a missfire on gate pressure of 9psi. Engine is a forged std stroke 26 with jun 264/270 9.5 mm lift cams (I think as these were purchased before my surgery) it has adaptronic ecu, split fire plugs running map sensor . New coil pack harness and bosch 2200 cc injectors with resistor removed. My tuner (jez) is awsome and has tried plugs, coils, harness , cas, adjusting cam timing as well as tune. He has adaptronic guy coming tomorrow to hopefully fix it but any ideas are welcome. He also did comp test which came back perfect. The engine also has new -5 turbos with ported manifolds and the head is mildly ported if that helps and smoke test showed no leaks at 2psi. The car was and is very difficult to tune and was a pig to get running at first, right now it has fresh shell 98 but has a flex fuel sensor waiting e85 tune if we can sought this miss out. Any help is appreciated
Scott
https://www.sau.com.au/forums/topic/426027-miss-fire-on-dyno-rb26-any-ideas/
  • Replies 60
Qualify - I don't know much.
But I would place a bet on your adaptronic ECU.
and therefore the course of action being taken by Jez and yourself.
Not much help but I think your on the right path.
Edit: Don't stress over it tonight :thumbsup:
Edited by Sinista32
I didn't but it was built by an engine builder in qld and was running 387kw without dramas when I purchased the engine it had travelled about 2000ks inc dyno work only change is cams and big end bearings just because I had sump off
Andy and jez spent 4 hours with it last night, swapped to another adaptronic , swapped injectors and problem still there so it's thought that its either due to wasted spark system or a mechanical fault yet undetermined. Jez is installing a nistune to see if it makes a difference other than that only thing we can come up with is put cams back to stock ones and if that doesn't work I guess engine out and full strip rebuild and blue print if all cc size of ports and seat pressures , ring gaps and clearances etc, fingers crossed but I'd love some ideas or if someone has experienced similar thing? I've search for at least 6 hours and I've found cams with Hyd lifters can cause missfire but these are solid type drop in juns? So no idea really
oh that was you that came past Jez's yesterday (he told me when u left) that was me working on my car while it was on the dyno...
he did mention (and I herd when he started it) that your top end is Very noisy, not sure if this may result in the problems you are having ?
Nice car mate very neat Install and nice power too! It seems I was ripped off with cams from a seller on here whom I can't remember due to surgery well there is a lesson don't buy important parts after brain surgery lol. Jez changed cams and it silky smooth and quiet. It seems I must have measured clearances wrong in thou instead of mm or something cause clearance was at least .75 when should be .30. Base circle much shorter as was duration and lift about the same. So stock cams back in and see how it goes tonight! Fingers crossed as we have both had enough of it that's for sure!
thanks mate she is my baby !
exactly lol always important to check clearances with every cam install !!! and if the base circle was smaller then it would definetly need new shims etc
well fingers crossed all goes well now keep us updated !
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
