CAN I PLEASE ASK A MODERATOR TO PLEASE REMOVE MY COMMENTS TO JACKY CHAN ON PAGE 30.
CAN THESE PLEASE BE DONE ASAP
http://www.skylinesaustralia.com/forums/topic/426059-forced-performance-hta-turbos/page-30
THANKS
The gtx does use metal cages, but the hta turbos are based off standard Garrett turbos
The Garrett based HTA turbos are based on Garrett cores, however the "FP" DBB turbos have metal cages - that covers the FP Green, Red, Black, Super94 and Super99 :) No doubt you can get the Garrett based ones with metal cages as well
Are the metal cages just for longevity? I know mine sure cops a lot of heat :ph34r:
Yep, is a durability thing. Though there are more than enough plastic cage GT users (my brother included) who have never had an issue.
Don't worry, just retain warranty information :)
Yeah have got all that ;)
I dont foresee any issues with the turbo i guess.... I would guess the thing copping the boost would let go first :laugh:
LOL possibly.
It should also be noted that Simon saw the same issue with his GT's that he did with the GTX that replaced it. I'm sure you saw the recent thread on that, so meh.
LOL possibly.
Nope? :blink: Link?
Strangely enough thinking about it I know of hardly any GT-series based HTA turbo failures - not sure I definitely know of any, and I know of quite a number which have been used for track racing etc. Like usual, it'll be heat that causes any major issues.... odds are if its not on high boost and it's not sustaining heavy thrashing for a long time there (hopefully) won't be an issue. Touch wood, it's be fine so far!
In 34GeeTeeTee's case I suspect the stock motor is the bit we should be more worried about :/
Haha it's had a good innings so far and will continue to get driven they way it should :P
Plenty of events coming up this year! I really should invest in a back up now i mention that!
Nope? :blink: Link?
Come on dude, I thought you were an enthusiastic forum member! Can't be falling behind like this LOL
http://www.skylinesaustralia.com/forums/topic/439625-dead-turbo-vid-inside/
Lith you are probably on the money (at least in my own mind). Hand in hand does pound for pound improvement go with improved efficiency, which is translated in lower charge temp and subsequent EGT. I would say the ratio of shaftspeed to flow at the compressor side has been engineered to benefit hotside flow, which would also greatly benefit.
All in all they are superior turbos, and likely to have better lifespan as a result.
Well there you go eh? :laugh:
I was off the forums for a while man, am hopefully back to make an ass of myself once again :yes:
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
