That Super99 makes some hot looking graphs. Damn..
That would be fun to play with, with a little more displacement :w00t:
Considering the suggested output I think a Super99 is as at home on a 2.5L as it is a 3L.
Its got a full kilo up its sleeve, not something that is as dependent on displacement as it is outright flow. If I am leaving you a little confused do a little reading on the reg changes for 2014 F1.
hey lithium, found more info from someone mounting them on a rb26.. spool the same or a tad laggier than -5s with a bit more power. Said however, the power gain wasnt worth the cost ( especially if they are bought at owen at 1100 euro/quid. Here in USA, its 600$us.. almost half price!).
I then asked FP and said they mainly sell the hta2868 to snowmobile with only 1 turbos.. dont think 1.3l is enought for a 68mm wheels, billet or not lol.
Althought tempting, I'm not really aiming for more power but better responce.. if only they had a 63mm ( maybe..) that could be very tempting. My search for an alternative to the expensive gtx is still on :)
I've had a flick through the website but I'm not familiar with FP's turbos. With the new 'Super' series do they have something that is roughly the size of their HTA 3582? I'm curious of how much power this could make on a 26. Just dreaming for now but I think these turbos seem very promising. I can't believe matt has been making almost 400KW from essentially a 3076 sized turbo.
No the "Super" series are just the 94 and 99, they are named that way because FP have designed their own bb core and turbine wheel combination which are specifically "BIG" hahaha.
I haven't seen any results on an RB or Dyno Dynamics dyno but at the same time have been following these things for a while - I figure the HTA3582 would be one of the most responsive mid 400rwkw capable turbos you could get, on E85.
What you mean "has" :P ................. Its still IS!! lolz
And loving it :yes:
THAT would make an impressive street machine. I wonder how the response would compare to say -5's. people tend to refer to those as being ancient and laggy these days but its certainly not a big power setup
Which are you comparing with -5s, the HTA3582 or the HTA3076? The HTA3582 would be quite an improvement in response, the HTA3076 wouldn't be comparable at all - its a much smaller turbo for a start.
Sorry, I should have been a bit more specific. I was making the statement in regards to the graph that was posted on the previous page :) from what was in the post, looks like the graph was for a 2lt.
Totally agree with your statement though, I think a 2.5 - 3lt would be more than happy to run this turbo. Just the whole ~150whp at 4.5Krpm on that graph leaves a bit to be desired on a 2lt.
This is of course if it were being used as a street and weekend track racer. If it were pure circuit/drag, then obviously the lack of low down power/torque wouldn't really matter, as you'd be hard pressed to end up below 5.5 - 6Krpm +
Awesome, I think I'll have a read regardless... seems like some good info. Thanks :D
NP
In a nut shell anything that will make full use of the available 103lbm is going to spend a lot of time a long way above 4k. My comments were more so in reference to anyone on SAU building an RB25 for big power. Personally I would not be too worried about an extra 500cc when talking 1000hp.
The added cubes isn't about to turn your 1000hp weapon into a purry little kitten with a 3071 :) Of course, this is purely academic. I can only offer you my opinion and until such time as proof is presented to suggest otherwise you should make your own determination.
Taking until ~4300rpm to crack 200kw would normally be counted as not terrible for a road car, right?
Here's a dyno plot from the soft initial pump gas tune for an RB30DET running a GT4202R - the old school requirement for 1000hp, with a lairy big cast 75mm/102mm GT-series compressor and 82mm (versus 76mm) turbine.
It's a lost closer to a mild boost level GT3071R pump gas setup on an RB25 than some might guess without looking into it - a Super99 HTZ would be quite an substantial improvement over that... the GT42 turbine alone is around 8% bigger, which is quite a large difference in turbo world.
It's a lost closer to a mild boost level GT3071R pump gas setup on an RB25 than some might guess without looking into it.
Sorry, I'm getting confused between this post and the one in the EFR thread defending a 300rpm improvement on the premise of transient response.
Eyes keep freaking out looking at that lol - you are right, well I still think it's 200kw at around 4500rpm... but yeah, maybe a bad example KINDOF but that's a HUGE turbo which I am not calling a response monster at all. Just kindof shows what a few cubes can do, Piggaz' car is hardly comparable when it's one mans mission to make the most powerful responsive "RB26" block car possible haha.
Point is, look for an RB25 making 500kw @ wheels and check what power it's making at 4000-4500rpm - then bare in mind this setup ended up almost hitting 8s in a full weight R34 GTR when it went "all in". That extra 500cc makes a huge difference!
So! Exciting news people!!!
Forced performance have just announced the release of their new FP 6466TZ!!! Basically it has the same/similar wheel dimensions as the uber turbo, PTE6466 by precision but uses Forced Performances new HTZ type aero design. Same design used on the Super99..
I am personally very excited about this new turbocharger. I cant help but think that FP have shot themselves in the foot AGAIN with this new turbo. No twin-scroll housing options...
  • Like 1
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
