So! Exciting news people!!!
Forced performance have just announced the release of their new FP 6466TZ!!! Basically it has the same/similar wheel dimensions as the uber turbo, PTE6466 by precision but uses Forced Performances new HTZ type aero design. Same design used on the Super99..
I am personally very excited about this new turbocharger. I cant help but think that FP have shot themselves in the foot AGAIN with this new turbo. No twin-scroll housing options...
I better bolt one on my car then :P
I want one of these
http://store.forcedperformance.net/merchant2/merchant.mvc?Screen=PROD&Store_Code=FP&Product_Code=NTGT3794HTA&Category_Code=Turbo-FP
But it can wait till I get bored of the TD06....which might be a while because Ive been on standard turbos for 4 years lol
I want one of these
Nah, I'd get the FP 6466TZ over that one. Faster spooling, same power. This new turbo is a game changer and will completely nerf the HTA3794R, especially with the Super94 in that range as well.
http://store.forcedperformance.net/merchant2/merchant.mvc?Screen=PROD&Store_Code=FP&Product_Code=NTFP6466TZ&Category_Code=Turbo-FP
If its based on a 6466 but with an FP compressor does that not mean you can buy a TS housing from PTE? Maybe they only ordered bulk of one housing style for the purpose of getting them cheap.
Doesn't seem nearly as dire as anyone is making it out to be...
Its based off a 8mm BB Garret CHRA.. :(
Similar name, but totally different turbo
Sent from my GT-I9505 using Tapatalk
Dang. Tonba your original post about it had me convinced it was a PTE with FP compressor, my bad.
Ye 8mm gt35 based worries me.
Considering the gt35s propensity to go bang with an 82mm comp wheel
Since when?
I actually believe it is the same / similar housing and turbine to the GT37 series. But could be wrong.
More exciting FP related news, the R35 GTR world drag record was just set by English Racing running an ETS twin Super 99 HTZ turbo kit - 7.81 @ 183mph, backed up with a 7.85 @ 183mph. Cool thing is they are still slowly winding up the boost throughout the run and tuning to suit, as they haven't been able to hold the power on a dyno -and now struggling to find traction to hold the power on the strip!
Definitely going to be more in this thing as weather warms up and they come to grips with it, not to mention pull some weight out - it's still not hugely far off full weight!
  • Like 1
GT2554R to GT3582R from Garrett anyway are based on the GT25BB sized centre section . T4R is the larger centre section inc P/60-1 T04Z GT37Rs GT40Rs T51Rs etc .
Imagine water cooled T25 and T3/T04B centres converted to BB .
I've also heard about GT3582Rs bending turbine shafts and lunching their compressors , from memory the section of the turbine shaft that the compressor fits over is slightly larger on a GT35R possibly to make it stiffer .
I also wondered how they were getting GT37 turbines into GT25BB centre sections and making them live .
A .
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
