thats a nice big shopping list.
Just out of curiousity, what sort of wheel studs/nuts do you use? has the track on the front or rear been widened?
rear has been narrowed, front has been widened with wheel spacers, ARP wheel studs.
Curious what clamps most people are using? Looking at purchasing some of these on the link below, anyone has any feedback please jump in.
http://www.ebay.com/itm/NEW-Pegasus-Aluminum-3-0-Turbo-Clamp-Clamshell-Purple-/310682635175?
pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item485620cba7
Great your addressing this... Better then silicone hose and clamps!
Ruined a couple of track days bc hoses would split and clamps would come off!
http://www.vpw.com.au/Category/Index/340906
Similar to yours... First time using them...just bc rep comes in every week.
:cheers:
I agree, thanks for your link Steve. So 21 days to finish the build and not sure how it will happen, things to do still...
Cryogenically freeze engine parts which will take a few days then put it together, add dry sump, waiting for throttle bodie and plenum to arrive, wire up the car, attach side skirts, fabricate cooler piping, finish off dash, maybe add fuel cell to boot, rear diffuser, lengthen exhaust, replace all bearings, extend jacking points, change suspension and alignment, add sponsor logos etc etc etc as this is half the things required. Busy weeks ahead.
Sounds like my list from last year. Compressing the work into a narrow time frame makes very hard work! Good luck mate. What event are you hoping to make to test or a PI open day?
The VPW seem reasonable quality. I have not put them to the test re big pressures or anything but those OBX-Pegasus ones out of the US are a bit...well didnt trust them. Either take a punt with VPW or go the whole hog and just by the genuine Wiggins clamps. Plazmaman now do their own version as well and may be an option...perhaps sponsorhsop ?
Thanks mate, at this stage not sure when the car will be done. There's on track events on the 16 July, might even take it to Winton just for a cheaper open practice day shakedown is probably a smarter bet as there's always issues with a new build.
Edited by stevena
I've read only positive feedback for the Pegasus but not from people running big boost or trustworthy sources. Will give vpw a call when I return from Hong Kong, as I don't know much about their clamps or people that have used them either. Steve ka if you are reading this who recommended the vpw clamps and have they used them in the past without issues?
Hey Steve,
Loving the hype you've created for wtac from Vic ;)
Double checked with Brad and had a good look at the design of the clamps today. Pretty much a rip off of the wiggans clamps. Maybe Brad can put some pics up if u ask him as I didn't get a chance to take pics. He was working on all the piping today
:cheers:
It's about time, we're bringing Victoria with us this year, not only does Victoria want the title but it has to be a skyline....no more evo's lol.
I've had a look at the clamps and I'm sure they should be fine, it's just nice to hear someone else has had success with em, as you don't want something as a clamp to ruin the event. If brad has used them in the past then its all good. Cheers steve.
Those clamps look like a good copy of the Wiggins clamps that Brad from Pro Fabrications uses. They work very well and cope with higher pressures than normal joiner hoses but you have to have to tubing aligned correctly.
Thanks victory.
And Steve, lol not those kind of late nights. Erotic nights business owner is a passionate motor sport fan and a perfect way to target the demographics for the business, without each and every sponsor we would not be able to compete at world time attack. The car that was may have been quick, but the new build is taking it to the next level.
Looking at a spare set of wheels 18x10.5 +22 offset, what's cheap and light, any ideas? Would love another set of te37's , they weigh bout 8.8kg but there not cheap. Looking at these work emotion cr kiwami weighing in at 11.1kg for $1850. Do you think these would look ok on the car in bronze?
Edited by stevena
Update progress report.........um, yeah, slow. Checked out my clutch we were using and it seems fine, twin plate and In very good condition. Wonder if a triple plate will be needed for the power we are running.
Tripple plate I know someone who has one cheap. LOL
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
