Ok guys great day and everyone's excited about the results today. We have smashed our previous record of 1.36.7. First session out dean pulled a 1.33.5 at a top speed of 298.3kmph, unfortunately paul and I rocked up late to record that lap and only have it on the go pro which didn't show the dash, second session out we did record a 1.34.2 and a top speed of 300.7kmph, will post this vid in a day or 2 when paul has worked his magic. The Audi r8 Gt cars were also out testing and there best laps were 1.35 as they too were battling hi winds today, their normal lap times are 1.30ish............so were freakin excited.
  • Like 1
Good luck for testing! The thing looks and sounds like an animal in the clip from yesterday, love it - should be intense with the power wound up to 11!
The NZ non-GTR owners also coming over don't count? :(
Lol! Sorry Mr Lith......I should have said Skyline owners! :)
Yesterday's test sessions, there is a good 1-2 seconds left with more time and better conditions. I really want it to break the 1.30 at phillip island but not sure if it can be done without a flat floor. We also had an additional 50rwkw we didn't use, like to play it safe for now. Thinks we might have to use all of it at world time attack. To get under 1.30 at smp... that would be cool but I think 1.31-1.32 would be on it without more test sessions.
  • Like 1
Love it! What box is it? You've probably listed it before but love that it's still H pattern! I can't imagine a 300kph brake into turn 1. 250 is fast enough!
Hey Russ, using the ppg dogbox with a Motorsport strain gauge. We couldn't believe it hit 300 and took a couple days to sink in what we have now built. All braking distances have now changed and need more test time to work it out. Car will now have a full maintenance program written out so parts can be replaced to keep it in good running order.
Thanks to all for your support and kind words over the last few months, feel free to come and say hi at wtac. Garage 15A.
Can a skyline finally take back the evo dominance at wtac? We're gonna try our best, and if that's not enough we will turn the boost right up.
  • Like 1
Looking forward to turning the boost right up, that will be MAD!!!!
That's good to hear. It's something very often overlooked and these cars are so far above their designed intention of a road car it's so important to check things on a routine/usage schedule.
  • Like 1
Damn.... this thing is supppperrr quick! Look forward to seeing it at WTAC and will come say hi and have a chat! Hope everything runs smoothly on friday and prep for saturday is good ;)
Kory.
  • Like 1
Good luck this weekend! Hope the 32s can muscle into the tops of the timeslips
Cheers buddy, what a amazing vibe and bunch of peeps that I finally had a chance to meet, some top quality cars too. Had a laugh. Practise day today had little issues such as a fualty oxy sensor and a stuffed coil, had about 10 laps so by the last lap these issues were finally diagnosed and will be fixed in the morning before first session. Deans first time with the car at this track and had to work out the best lines etc, pulled off a 1.34.8 but not a true indication as yet as he hasn't had a full on go, traffic and issues held him up. Although what is apparent is our tein suspension is not good at all at this track, phillip island is flat and it's fine but here it's evident that it's not good enough. Might have to look into mca gear. Can't wait for tomorrow to hopefully lay down some good times. Will keep ya posted guys, cheers.
Another massive day, loving time attack but wish there was more drive time but you get that with so many cars. First session out today and a lap time couldn't be set as a car in front had leaked oil in the track. Second session out dean pulled out a 1.33.0 to take the lead from the evo 10 go pro by 1 second. Top speed on the straight hit 290km/h on the 3rd session out but gearbox issue struck and ended that hot lap. Gearbox is being sorted so we can be back in the morning for an all out attempt. There's about 2 seconds in it as current set up. Have learnt a lot from this event on what's needed to be done to break the 1.30 if attending this track again...first thing is ditch the teins. Big thanks to all that have come past to say hi. Keep ya posted tomorrow.
  • Like 1
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
