OK so as the first GB was successful and a lot of people are keen for round 2 here it is! I have been in chats with the supplier and there is a 2nd OPTION!
differences between the units are as follows
- Option 1 has IR for night and a G sensor
- Option 2 has full 1080p 60fps (as apposed to 30fps on the option 1) better battery and a newer version of the Ambarella chipset
majority will rule on which cam we go ahead with as i cant do a 5/5 sale
Price will be $139.95 per unit
- 10 units for the GB to go ahead
- $50 deposit up front for order
- Once 10 people are in remaining money to be paid in full prior to order being placed with supplier
- All units will be sent directly to myself then i will send them out (easier to track that way)
1. gtr0321994
2.
3.
4.
7.
8.
9.
10.
OPTION 1
This is the first cam that was purchased in the first GB
Specs/details will be below
Product Features
  • 120 degree ultra wide angle lens, focus range from 10cm to infinity
  • 1920×1080P full HD high quality resolution
  • Advanced H.264 video compression technology
  • 5 mega pixels CMOS Sensor
  • 1.5 LTPS TFT LCD, high definition, can watch while shooting
  • 4×digital Zoom, ranges from 12 cm to limitless distance
  • Support HDMI high quality video transmission
  • 5 resolution forms can be changed for video flow
  • 30/60 frames per second for smooth video flow
  • Equipped with special auto suction cup holder. Conveniently fix and use
  • Built-in GPS logger, and google Map, can record driving track and so on
  • G-sensor to keep records of sensor data and real-time display on the player.
  • Matching IR Light for supplementing light at night
  • Seamless continuous recording, will not miss any data
  • Powerful document protection, even in the recording process, the occurrence of sudden power outages, machine damage, etc., video files will be intact
  • Adopt auto cigarette lighter power supply, to make the video recording while driving
  • To start the auto automatic off; to start the video recording function
  • Automatic circulating video recording, being able to set the recording time for each file
  • Watch video while ma king video recording in driving. Support on-spot play back
  • Improve time & date display, no need to reset when re-start
  • Set the video recording time, stop recording when the setting time is up
  • Screenshots function, can capture the video screen while video recording and reviewing
  • To charge through USB
  • Human orientated operation interface
  • Maximum 32G or even bigger SD high capacity storage device
Technical Specifications
  • LCD Display 1.5 TFT LCD(4:3)
  • Camera Lens 120 degree wide angle, 4 fixed focus Lens, aperture 2.0,focus 3.4mm
  • Sensor 5M CMOS Sensor,1/2.5 light-sensing surface area
  • Zoom 4×digital zoom
  • Video Resolution H.264 compressed format1920×1080,30 frame/sec1440×1080,30 frame/sec1280×720,30 frame/sec848×480,60 frame/sec848×480,30 frame/sec
  • Video Codec H.264
  • Picture JPG file format Maximum output pixel:5.0 mega pixels
  • Circular Video Functions Support
  • Y/M/D/H/M Support
  • Carrier Media Built-in Memory (Available:21.1MB,Total:32MB)
  • Photograph Mode 5 mega pixels CMOS
  • Audio Microphone and speaker(AAC) equipped
  • Memorizer Memory:32MExternal Media: SDHC(support 32G max), TF card
  • Flashlight Automatic/Manual on/off electronic video supplement lamp(LED)
  • Video Output AV-OUT / HDMI out
  • Video Format PAL/NTSC
  • Current Frequency 50HZ/60HZ
  • USB Function 1. Memory Card2. PC camera
  • Shutter Electronic shutter
  • Battery 500mAh 3.7V Polymer Li-ion battery
  • Package Size 18cm*14cm*9cm
Option 2
Product Features
  • GPS Satellite positioning (tracks route and vehicle speed)
  • Full 1080P High Definition recording
  • 5 mega pixel sensor
  • Seamless cyclic recording, that is recording over old data when capacity is reached
  • Date/time stamp option
  • 2.8″ LCD display
  • In-built microphone
  • Motion detection
  • Accessories included: USB cable, car charger, bracket, holder, user manual
  • 1920P x 1080P full high definition @ 30 frames per second
  • 1980P x 1080P high definition @ 60 frames per second
  • Ambarella A5 + A3135 chipset
  • 5 Mega pixel CMOS sensor
  • Crash impact sensor to preserve footage in case of damage
  • Supports MicroSD card 512MB-32GB REQUIRED – NOT included
  • 3.7V 800mAh rechargable Lithium-ion battery
  • Product size and weight: 10.5*5.5*2.1cm, 88g
  • Memory usage: 86MB/min – 5.1GB/hour
  • 1.5 hours approximate battery life
  • 2.8″ TFT LCD Display
  • Wide angle view 120º
acEw54Q.jpg?1
dah56BC.jpg?1
Bank details for payment
NAB
BSB: 082620
ACC: 136401639
ACC Name: Damian Hunt
Please PM me receipt details once payment is made and use your username as reference (so i can find it)
Edited by Frosty
https://www.sau.com.au/forums/topic/426240-group-buy-full-hd-dash-cams-round-2/
Erm anyone's got the night view for option 1 loaded yet and also can confirm if it has GPS function (Australia Map)? I'm assuming camera has local warranty too? If every so, I'll be down for option 1. Cheers.
x 2
Is option 2 basically the same but better camera and battery and smaller size??
Just want to make sure it will still work at night
Option 2 is better again! works at night no issues! given i have been using option 1 myself the IR actually RAISES the ISO and causes the image to go grainy! Thus its better to have it turned off
video to come :)
I'm in the midst of selling the minster of finance on this idea... will get back to you ASAP.
no probs
x 2
GPS tagging anywhere in the world! Yes aus warranty on both cameras! Option 2 is the better camera all in all :)
FYI
I have option 2..
It does not do 60fps at 1080p or even 720p
Of a video i did:
1920*1080
Bitrate 9169kbps
29fps
Audio 127kbps, stereo,48khz
It only does 60 fps at 848*480, even then i havnt tested it.
I havnt tested video quality yet.
Edited by jay-rod
FYI
I have option 2..
Of a video i did:
1920*1080
Bitrate 9169kbps
29fps
This i will confirm with my supplier as to what the deal is.....That being said could be a different camera or a copy to the one listed that you have
I use option 1, still gotta test a few different things with the Night View, but I find it a good camera. Although it focus' slightly on the window more so then out on the road.
As to wiring, mine is still on the cig lighter, but once I get my R33 going it'll have the plug cut off and it's just a simple 12V accessory and earth that needs connecting.
That being said, if this GB wasn't so soon, I'd be buying a second one of Option One to shove it in my rear window.
Magically cars have mostly stopped attempting to kill my front end, and they're now trying to smash the back of my car!
yeah i was going to do that, but I opened up the plug and theres a small PCB (with probably a step down transformer - the manual says the camera needs 5v not 12v) which i figure needs to stay. might just pickup a spare cig lighter socket form ebay and wire that in, then plug in camera
locked up the brakes in the wet today because an idiot decided his lane was too stationary and he wanted to be in the adjacent lane (mine) in which traffic was moving at 70 odd km/h. ended up within a meter of his rear bumper.
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
