Let's try to breathe some life back into this forum shall we? if you're reading this post, post up at least the last one of two shots you've take or uploaded. Even if they're not really relevant to cars or what's going on. Share and chat! Let's do it!
I've been away for a while, but I'm back now! Got hitched at the start of May (thanks to Gav for the awesome photos ;) )
Afterwards, we hit up Europe for a few weeks :) Well I'm home now. I'll be running through the euro shots and sharing whenever I'm bored. Here's the first few :)
https://www.sau.com.au/forums/topic/426333-june-photo-thread/
  • Replies 54
Sure easy for you to say, Mr EuroTrip. :nyaanyaa: Nice Pics.
Hmmm... to contrast your beauty shots, here's a little guy I found when working on my resurrected 20 year old Project car from the US. taken with my crapy old iPhail.
180fan good pic. Lower the ISO though.
another recent pic
Yeah I had it up way too high, I haven't really taken many nighttime photo's before so was just playing around with settings as much as anything else. At least I know for next time
Heres another
Car looks great. But (and i feel like an arse giving you two lots of negative feedback)
- The focus filter you're applying. I have never ever seen it look good on anything. It just leaves me with a headache from my eyes trying to focus.
haha its all good man, at this point im just messing around with different things, seeing what works and what doesnt, so any feedback is welcome
The main reason I used that filter is because its one that I have seen a youtube tutorial for previously, so I knew how to do it :laugh:
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
