What Is 'too Much' Power For The Street?
74 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
no 500kw car is going to be convenient or street friendly on a daily basis..and the price of fuel and wear and tear will soon have you buying a barina to get to work in....
doesnt mean it cant be done though, but even a 300kw car isnt always great on a daily basis...there are far more comfortable ways to get around...
Would I not drive on a street a 458, GT2, Veyron, Koeniggseg, Aventador? How much power do they have? Why would I not then drive a big HP GTR on a street just because my budget is lower?
Now what street are we talking about?
Now Mr Willis's private 'street' up on the Central Coast looks the goods.
According to JEM's latest Lambo tests they come from factory with bugger all..... Twin turbos should soon rectify that!
300 odd rwkw is getting closer to 'enough' for the street.
Would not go any bigger on a cam than what I have for a manual and regular street driving, too much overlap = a prick to drive smoothly through lower gears. Stalled auto = no problems.
I'd say the upper limit would be where you can't start opening it up without losing traction - tyre choice, suspension of course play a big part in it.
Same with big turboed imports - my old R32 was laggy and it sucked balls unless wringing its neck. 4.3:1 diffs did help with that though.
All depends on the car.. A 400rwkw Silvia is alot more silly than a 400awkw GTR.
Perfect daily street car would be a mild low 300kw GTR (-7s or -9s). Standard looking engine bay, relatively reliable, mid - high 11s quater mile on street tyres and not all that expensive to build. Once you wind up the power things tend to go bang..
In saying that low 300's does get boring :rofl:
Sif high 11s with them mods, i did that time on stock turbos and stock ecu ! 234kw
I hope to run a high 10 with that setup :yes: :yes: :yes: :yes: :yes: :yes:
Edited by sultanaz
My 26 GTS4 with 280 odd kw is more then enough on the street - to the point were i haven't even touched the high boost setting
Mind you its running RWD at current so i take it half easy - and is the first Forced Induction car i have driven so of course it feels quick to me
The power im getting used to it....
Hard question to answer but id say even 200kw is more then enough
Boost level and power level is still all controlled by the right foot :P
I agree with that for sure and just because a car is 300, 400 or 500kw that does not mean it has to be driven as such
i think better wording then "Too much" is usable
Yep, its the good thing about modern turbo cars :yes: Can be driven daily without knowing its got big power! Mine is smooth as on the street, its only the idle that gives it away now!
I hear you brother! the straight exhaust with single hooker muffler can be quite loud haha
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
