Hi guys got my car back tonight with a cruise tune of almost 240kw at 11 psi, I have a very slight leak I have to rectify around #3 inlet manifold hopefully simple. Anyway with the adaptronic 1280 and Bosch 2200 injectors I was suprised how smooth it was especially for quick tune . This ecu is crazy and has everything even launch control and almost anything it's completely programable in every way.
Thanks to jez and Andy btw, but we were talking and I really want 400 kw plus on e 85 so we decided to put cams and possibly springs , it's a forged engine std stroke with mild porting in cylinder head and exh manifolds. So do I just go the usual type b as jez said they are proven or try a custom grind still with full size base circle but 10 mm lift or more? And say 260 duration to keep power band low? I don't want to change shims as right now it's perfect and super quiet all I can hear Is injectors. It also has hks adjustable cam gears , we can change them out in about 2 hours but I just want to give it best chance offline the power, car will be used for drags and hill climbs etc not much circuit. I have researched around 6 hours on this subject but posts go back to 2009 so if there is a thread please direct me to it.
Scott
https://www.sau.com.au/forums/topic/426538-got-car-back-tonight/
Chuck a HTA 3582 on the side of it and have epic response AND power.... I replaced my GT3037 with a HTA3076 (same size turbo) and made 391kw and super response!! The car is totally different now and just the way I want it!!!
I want to stay twins but I know it's heaps easier to make the power with a single It looks like I will go a camtech grind 272 , 9.75mm lift depending on my clearance measurements on stock cams or I may get him to reduce duration a bit
Guys Scott has been discussing his car over a couple of threads, the setup is done... No need to discuss alternate turbo options etc. Just cams.
Having only done a little research I am with Jez on the Tomei type B's. You don't need anything too massive to hit your targets, and a tried and tested combo seems like a safer option than trying a custom combo.
Can't deal with new shims lol I think it "should be ok in theory as the valve seat and valve govern the distance and shim required and supposedly with 32mm base circle all should be well, supertech do a dual spring with 92lbs seat pressure is that overkill ? Can u go too far with springs ? And sir rb those cams I had were 29 mm base circle hence the dramas but I should have run thicker buckets to compensate, it's good cause u don't need relief but bad cause of mucking around
valve springs will be 20yrs old.
more boost, high rpm, do the springs while its apart.
just a decent single spring.
and new cams will still need shimming.
even with the same base circle, shims are .05mm iirc, sfa in it, and I dont see machining/casting being that spot on.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
