Uh oh ran into trouble... Turbo is struggling to make power. So far the airbox has been eliminated as cause. May be Nismo exhaust or turbo. Only making 230kw at 18psi tapering to 15. Cam timing is correct.
Jez is on it trying to diagnose.
Boost leak could be the issue but then again, its Jez and Im sure he would have picked it up at 1st sight.
If you want to test the cross over style FMIC setup. I have a spare Hybrid intercooler core & Im sure someone would have a spare set of pipes for the cold side for you to test?
Hope it's a simple fix mate. I know Stao did a but of comparative testing for intercoolers and found the blitz and similar turn flows had a much higher pressure drop compared to the other style. Definitely wouldn't account for that much of a loss though, mines certainly fine.
I hope it's not a compression issue. Fingers crossed for you
  • Like 1
Thanks raj!!! I have my old cooler just a Kkr front mount and pipes That should be good right ?
Should be a good start in trouble shooting.
Cue the beer and long weekends in the garage.
  • Like 2
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
