  • 1 month later...
  • 2 months later...
Bit of an update, got the front flares to a point I am happy with.
Started on the rear flares, cut the bottoms back off and started again.
Wasn't happy with the bonnet hinges I made so decided to use VE commodore boot hinges, had to create a pocket each side for the hinges to sit in.
Also welded up some holes and seams in the engine bay.
  • Like 7
  • 4 months later...
The motor has been dropped off at JPC and the seats are at the trimmers.
Cut off the sill to repair the damage.
A9X_0326_resize.thumb.JPG.fdcd881b7d495a75dfc15ae80758a638.JPGA9X_0331_resize.thumb.JPG.145c3361d04b751fe060db51d9f18382.JPGA9X_0337_resize.thumb.JPG.446a6f9ffd9ac0229637073ea219cbe1.JPG
Had the shell dipped at Recoat paint stripping and have now started spraying the epoxy/prime.
A9X_0367_resize.thumb.JPG.a535e0a84ba02957099127e10660315f.JPGA9X_0394_resize.thumb.JPG.768f75669ffb32abb382935ed32bb676.JPGA9X_0396_resize.thumb.JPG.a8b104121d4f9f16cb24f756fec06e07.JPG
  • Like 7
Yes had it dipped at Recoat paint stripping, they work out of their shed behind their house. I don't think Recoat smash repair are going anymore after the death of a worker the other year.
  • 2 months later...
Update time. Having the shell dipped has turned out to be more work than I thought.
About 14 holes have been drilled in the shell that they never told me they were going to do so these had to be welded up.
Yes that is a hole drilled in the middle of the roof skin.
I was surprised at the amount of rust that started to form under panels, I had tack welded the sill panel and two extra roof braces on to the shell and removed them when I got the shell home.
There are also spots where it looks like acid is still leaching out of the seams.
A9X_0399_resize.thumb.JPG.d734ffef3962fade3451ea325c3a0d36.JPGA9X_0400_resize.thumb.JPG.a6e553ccf8c207c9fa18260d84015fc2.JPG
I was also surprised at the amount of body deaden-er and seam sealer that was still in the shell.
The black shape in the middle of the photo is one of the many big of body deaden-er.
I have had to strip and clean and sand every part of the shell so finally got the inside and underneath painted with KBS.
One coat of silver KBS, still need to seam seal then a coat of black KBS.
  • Like 4
Were the holes for drainage? breathing?
And yes, poor form not to at least advise. Maybe they assumed you knew? First I've heard of it but I have never done this level of work to a shell.
I've never thought of painting the inside of the body with KBS. My plan always only included doing the under body...but now you have me thinking....
Will this be the only form of sound deadening in the interior, or will you still be putting something like Dynamat under the carpet? Or, is this KBS just a sealer / rust killer paint rather than a sound deadening coating?
Edited by Tenny
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
