  • 1 month later...
  • 2 months later...
Bit of an update, the rear bob tail needed a but of work to get the gaps better, basically cut off the side of the outside pieces and fibreglass them back on and add some fibreglass to the centre section.
Got a couple of coats of All-U-Need poly primer on the shell and started sanding.
  • Like 4
Perfect finish on the bob tail Glen, looks awesome.
I might hit you up to come around for another look soon, I haven't seen it for a few years now!
Look forward to going for a cruise at some point too. Looks like we'll both be finished fairly soon.
I still get excited every time there is an update on this.
I too am very interested as to the color you will paint it.
I vote Midnight Purple III ?
1 hour ago, ActionDan said:
I'd almost lean more towards Torana palettes.
Orange with black strips etc.
Whatever you choose, I'm sure it will look nice.
1 hour ago, R32GOJIRA said:
With the SLR type flares, maybe custom SLR2600 graphics.
definitely factory style and colours but with a modern twist. this colour combo but a Pearl White and Metallic Black
16 minutes ago, turbo76lx said:
The colour is going to be mandarin red with black outs around the side window and tail lights but probably not the black bonnet.
Still keeping the current black wheels?
great to see all the effort will the small details.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
