I've had e boost, never again, HKS EVC
You generally get what you pay for
Not always true, I had a HKS EVC and it was the most unreliable POS on the planet, it was replaced by the Greddy and the car now has a better boost curve...
https://www.sau.com.au/forums/topic/427056-ebc/#findComment-6892086
That's right thats why I said generally, I have two EVCs now ( 4 & 5 ) and never had an issue, but both came up at good prices when I needed something, so either I've had a good run or your one had an issue, who knows but I know I'd wouldn't ever go the e boost, I spent hours setting up and CRD tried and no matter what we did it wouldn't catch how quick the 32 came on boost, fitted the EVC and with no setting it up had no more problems, been in car for 8-9 years so far
https://www.sau.com.au/forums/topic/427056-ebc/#findComment-6892206
eBoost = great, but overpriced considering it's is just using a MAC valve
Profec = great, decent is price, uses the same MAC valve as most controllers
EVC = awesome, stepper motor holds boost well
Blitz Dual Spec-R = awesome, dual solenoid holds boost so flat you could put a ruler on it
Turbosmart Dual stage = junk, awesome spike
Turbosmart Single stage = junk, awesome spike
https://www.sau.com.au/forums/topic/427056-ebc/#findComment-6893160
A mate had plenty of issues with the original series, in saying that i believe the retard tuner was partially to blame!
Yep i know a few that swear by them hence my purchase, as usual i am just unlucky lol
ive noticed alot of people running greddy profec ebc's are they way to go, hold boost like they should?
Yep, do the job fine! Work well on my car!
:laugh:
https://www.sau.com.au/forums/topic/427056-ebc/#findComment-6893172
^ true story, my 180 came with one, first mod was to remove it and sell it. Then my current shitbox came with one, removed it the first day I got the car, and sold it on eBay.
Biggest croc of shit on the planet, essentially it's just a pos bleed valve with a solenoid to enable the bleed or not.. total shit, however their external gates are good. They should stop making boost controllers LOL
https://www.sau.com.au/forums/topic/427056-ebc/#findComment-6893203
A gate technically controls boost, so therefore would be a boost controller? :blink::laugh:
https://www.sau.com.au/forums/topic/427056-ebc/#findComment-6893206
thanks for your advise guys appreciate it. I'm thinking i might go with the Greddy ebc that option seems good value for cost.
I have researched before but it is easier to ask the question and get direct answers instead of sifting through junk on the net.
thanks for the help matt.
https://www.sau.com.au/forums/topic/427056-ebc/#findComment-6893868
You should be right with the Greddy...
https://www.sau.com.au/forums/topic/427056-ebc/#findComment-6893897
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
