Got a mate's new 25/30 running today but the oil pressure seems to be a lot higher than it should. Was over 100psi at cold idle. It's currently got running in oil in the engine and has 2 x1.5mm oil restrictors to the head and I'm 99% certain a RB25 oil pump. The vct has an external feed to it but isn't wired up. I'm running a 25 pump on my RB30 and its only got around 60psi at cold idle. Is there any logical reason why it would be running such high pressure?
Also the vct feed is a -4 line. Does it need a restrictor in it at all or will it not matter as we most likely won't be wiring it up so the oil will just drain back to the sump
Edited by PSI086
https://www.sau.com.au/forums/topic/427432-rb2530-high-oil-pressure/
The oil is a Penrite running in 20/50. Going to run a 10w in it once its got a few km's on it and is ready for synthetic though. Might just see what the pressure is like with the proper oil and normal running temperature. I can't see any reason why it would be higher than a normal RB25 as everything is identical besides the lack of oil squirters under the pistons
Just got the car running with the RB20 tune which was in it previously so can't really take advantage of the vct just yet. Will most likely wire it up though. From what I understand it just needs to be activated with an rpm triggered relay?
  • 7 months later...
sorry to bring up the dead guys but im going though the same drama at the moment with my rb25/30 non vct that's just being built and getting tuned
120psi on cold startup and idled at 1500 on penrite running in oil. this seems worrying!!!???? potential to blow seals etc?
im reading this from a auto meter prolite mechanical gauge.
not sure what the warm oil pressure will be just yet as I haven't let it get to that stage yet.
the oil pump is a rb25det pump with billet gears.
block has 2x 1.3mm restrictors and the vct line is disconnected.
ANY IDEAS ON A FIX??
oh shit! that's high for cold start!! once warm that aint to bad! wat oil ?
at what point do we start thinking f**k that's dangerous could blow rear main and front seals etc?
hasn't done any kms, 1st startup was today and after about 10seconds I noticed it was sitting on 120psi at 1500rpm (didn't wana rev any higher plus 1st EVER start up for the engine.
  • 3 months later...
hey all, find any solutions to these 25/30 high oil pressure issues??
my freshly built forged rb25/30 is showing over 100PSI on my autometer mechanical gauge, oil features include:
tomei oil pump
2X1/3mm restrictors
-12 rear head drain
2X-12 sump breathers
2X-12 cam cover breathers
grub screwed VCT feed in head
VCT sensor removed and capped
drilled out oil drains in block
2L accusump
5.5L sump
19row mocal cooler
GREX oil thermostat and oil filter relocation with ryco z145a filter
on penrite running in oil 15w40 it was showing high oil pressure over 100psi on cold start then down to 90 once warm. a tap of the revs to 2500rpm and it went to over 100psi again (gauge only goes to 100psi). after 250kms the oil was drained and a penrite 10w40racing synthetic was put in. once again on cold start over 100psi but once warm it dropped to 80/85psi or there abouts at idle and only went over 100 after 3000rpm
I was thinking of going a lighter viscosity maybe a 5w30synthetic or something? I only use penrite.
could anyone recommend anything?? or does anything look out of place? im a little worried.
I think im going to get a larger scale mechanical gauge to see where there press really sits after 100psi..
I previously had a rb25 pump with billet gears and was showing the same signs
any help would be HUUUUUGELY appreciated im really stumped and worried.
Cheers
Corey
Edited by ScreamerNewbie
If your bearings clearances are all standard then use a standard viscosity oil which I think is a 30 weight?
If you cant get the pressure to drop when warm below say 120psi at full noise where the oil relief is cracked open then you will need to reduce the spring pressure in the bypass of the pump. If you don't want to do that then you can hook up an external Peterson oil pressure regulator between your sandwich plate and oil cooler/filter arrangement and plumb that in so you can regulate the pressure going into the main oil gallery.
  • 3 years later...
On 10/15/2017 at 10:38 PM, pet vl said:
And iam still haveing trouble any idears its my car looking i to changing the spring in the pump HELP
Be more specific...what is your problem? What is the cold oil pressure and how long does it take to drop to say 100 psi?
I see your other post - just post in one place!
See what happens when you compare the spring pressures.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
