Yep that RX7 looks like a street car.... LOL
And for those saying the GTR is too heavy, you obviously know nothing about Kazutoshi Mizuno's design philosophy and intent - and I'm pretty sure knows his sh1t.
Let's face it, the R35 needs a weight shedding surgery. But I'll give credit where credit is due, it is a good car but it just seems dead inside the cabin.
A driver with an extensive skillset can pilot lighter RWD's such as S15's, RX7's etc to destroy the R35. And these lighter RWD's will be more fun and useable on the street.
And as can be seen in this video, the lighter FD looks a lot more fun to drive due to the inputs required and in-cabin noise etc.
Some of them are burnout/drag cars and have been for over 12 months.
So no mods at all, if not send me a message when they lose compression. The blow by is the biggest issue together with valve float at the limiter, and oil being dumped into the intake. If they haven't yet tell them to put a vented catch can in because the blow by is ridiculous.
I'm thinking that the most impressive feature of the GTR is that it can do what it does so easily. For other cars to compete they need to be stripped and highly modified and then yes they are raw and challenging compared to the sedate GTR. The same GTR that can go to the shops and drop the kids off at school with ease. If you want a raw and loud GTR you are then in another league again.....
Edited by AussieMark
  • Like 1
First couple of thousand km's I only drove my 35 around the city, and yeah was pretty boring, but to be honest any car would be, and for sure it was too fast - couldn't really give it a bit since it's pickup is unreal.
Then I've done a few mountains drives.... around 1300km's all up, and I can tell you that I was not bored for a minute - it was definitely the best car I have ever driven, fast, engaging, but was still a bit too quiet with its 88dBa stock exhaust.
For sure I can see that 35 needs some room to get its legs stretched and to get into the groove - and for sure I reckon track days are a must - but they are a must for any performance driver with a fast car these days if you don't want your car impounded.
  • Like 1
I agree with a lot of what has been said in thread. For most guys here the R35 would be the current epitome for production cars in the Nissan brand and it can clearly be seen why, it's a world beater. However, comparing it to older and less advanced cars is kind of pointless as is the case with many changes with technology. Throw in cars (in similar money brackets) such as M3 or C63 and you get similar stories even though they are RWD. Driving a M3 and sometimes it feels the car is doing all the work for you and again it is surprisingly quiet. I guess it just depend on what you are looking for in the car as an everyday car, track car or bit of both. Either way, awesome car!
for sure?
Having a really fast car is like having a 2 foot long penis. Great fun showing it off and bragging about it, but good luck finding somewhere to use it properly.
And here I thought having a really fast car was because of a small penis!
i have two fast cars. logic states im 1 inch on the chub.
you have a fast car and a fast bike. you must be inverted!
hahah!
On that note, how handy would inverted junk be? No more nutshots, no more "reallignment" in public. It wouldn't get crushed against the tank everytime I slam on the bike brakes!
Speaking of...I propose that my bike is more boring on the street than an R35. At least you guys can change gears when giving it stick; I'm doing 165 before I have to consider leaving 1st and the police don't like me at that point.
It's amazing how all issues eventually lead to this train of thought... Ha Ha ha. How about if someone's has big brakes? What does this tell us about his or her private parts.
savage lack of testes.
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
