hey im looking at getting this:http://www.ebay.com/itm/88-NISSAN-Z-300ZX-VG30ET-SOHC-OEM-TURBO-TURBOCHARGER-/290887740617?pt=Motors_Car_Truck_Parts_Accessories&hash=item43ba42acc9&vxp=mtr
what else would i need to install this turbo? has anyone done it before and got any tips?
any help is appreciated.
https://www.sau.com.au/forums/topic/427642-vg30-turbo-on-rb20/
Don't do it. That would be shitter than shit. If you want a VG turbo, you want the single turbo from the VG30DET. That is basically the same turbo as the the RB turbos, with an OP6 exhaust housing. A sensible upgrade option on an RB20 that has been done 10^55 times before and the specific tricks (not that there are many) would be found with a few seconds of googling.
VG30 on a 20 is crap, dont do it. I did the swap on my hr31 and it was really laggy, to the point that normal daily driving was a pain in the ass. I changed back to the stock turbo I hated it so much.
Go a highflow of the stock turbo, much better option, not alot of lag but alot of potential, my 32 had this and it made about 230rwkw and less lag then the vg did (tune would also help with that)
Dont put a op6 rear housed turbo on a 20, worst thing you could do in terms of drivability, would only be good if you used it for a highflow and wanted 250rwkw +.
Really any turbo bigger then stock is gonna suck unless you get a tune.
Define "recondition" though. These things are BB centre and ceramic turbine. Recondition usually means highflow which really just ends up meaning keep the front and rear housing and get all new the rest.
not sure what actually done to fix it but it was smoking worse than a ten pack a day cancer candidate , after it was reconned it was all good- no smoke
didnt know the VG30DET turbos were BB but knew about the ceramic part of it
Yep the right ones from the Z32 300ZX quad cam single turbo cars are BB . Really the only usefull thing on them is that OP6 sized turbine housing and it's arguably too big for an RB20DET .
So , many people just fit an RB25 turbo because they are common and generally cheap . Compared to a std 20s turbo the 25s one has a very slightly larger turbine housing and the same sized turbine . The compressor wheel is larger as is the compressor housing and it also has a kind of anti reversion groove machined into its snout .
Your call but I think an RB25s turbo is a better suited to an RB20 and they are much easier to find . Do a few searches and see what others thought about 3L turbos on 2L engines .
A .
I quite liked driving around an R32 with a VG30 OP6 turbo. Wasn't as laggy as the horror stories make out, and gave much more power at 12psi than the RB20 turbo had done at nearly 15. And this is coming from me, who whilst I appreciate that the RB20 is actually a good motor, used to absolutely hate the torqueless characteristic they have until they come on boost.
I must agree however, that if just looking for a mild upgrade, the RB25 21U is a better choice.
Edited by GTSBoy
A .
i think youll find the z32 was twin turbo or non turbo not single turbo
Edited by StevenCJR31
No thats not true , there were single turbo versions of the SOHC (per bank) VG30"ET" and DOHC VG30"DET" . The one most people know about is the VG30 "DETT" Which had twin inlet manifolds and forward facing TBs . And a hybrid T2/T25 turbo on each exhaust manifold .
The single turbo ET and DET versions had a crossover pipe behind the heads to feed one turbo from two exhaust manifolds . The ET or Z31 (SOHC) version from memory had a plain bearing ceramic turbo with a smaller center section and no preload bolt head visible on the side .
Have a look at the last couple of pics in this link and note the "Ceramic Turbo" badge .
http://www.geocities.jp/ayanami31rei/Z31-report/656-ayanami300ZR/656-ayanami-with-vg30det.htm
Cheers A .
Edited by discopotato03
yep; there is confusion but it aint coming from me,as i said to disco before the z32 300zx didnt didnt come out with single turbo , it came out with TT or no turbo (VG30DETT or VG30DE)
the vg30det came out in the y31 cima and other luxury japanese cars
it had twin TBs on the passengers side of the engine and has the single(ceramic) turbo which i wilbe putting on my rb30det
I have a VG30DET turbo sitting in one of my R32's at the yard, from memory the 32 was great with it on, i see no issue in using the op6 or 30DET turbo on a 20 as you can put more boost through em than a 20 turbo anyway.
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
