Hey guys,
I'm trying to build my own oil cooler kit and I need some help with fitting and hoses.
I've bought:
-GREX sandwitch plate with built-in thermostat (-10AN outlets)
-Mocal 19 rows oil cooler core (5/8BSP outlets)
So I'm just wondering what's the best fittings/hoses to use to join both of them up.
I'm thinking of using -10AN braided hoses, so I'll get 2 x -10AN to -10AN hose and 2 x 5/8BSP to -10AN hose? Is that correct?
Also, any recommendations on where I could get them from?
Cheers
https://www.sau.com.au/forums/topic/427723-oil-cooler-fittings/
I used Speedflow fittings and hose (115 teflon / black nylon braid) from motorsport connections in Moorabbin https://www.mscn.com.au
Speedflow seem to be the best fittings I have seen, but check out Proflow as well - I think they are cheaper. Bends etc are not as tight from what I can see but the Speedflow ones are off the planet expensive. A good tip is the straight fittings are much cheaper than any of the bends so if you can get away with a straight its a good thing for the wallet.
Google proflow - lots on ebay and I think you can buy them direct from their website.
Thanks Paul, I've been looking at speedflow and aeroflow, both on ebay. But I can't seem to find any of those fittings for 5/8BSP, as that's the outlet from my Mocal oil cooler... Any recommendations?
Yeah give Motorsport Connections a yell - they haven't failed me yet with being able to adapt to whatever is required. Not sure about ebay but I think Speedflow control the price so generally they retail for same from all dealers.
All the coolers I have dealt with have had AN fittings (JIC) or a metric female boss fitting that you can screw your desired male adapter into. I think you will need an adapter to use the Speedflow stuff on a BSPT but give them a call, tell them what you have to connect and find out your options.
Yeah, my Mocal cooler seems to have a built in male BSP connection..
But will give them a call for sure, as they are close to me too.
Will keep you guys updated :)
Cheers
Mine are all MSCN speedflow! Awesome gear!
^^ +1
I had nothing but issues with Proflow teflon fuel hoses and fittings leaking, TorquesUK has helped me out many times with braided lines for fuel and oil without a problem.
For oil I prefer the black nylon braid rubber cored hoses for oil cooler lines, as it is very flexible compared to the stainless braid. http://www.ebay.co.uk/itm/10-AN10-Nylon-Braided-Stealth-Black-Hose-1m-/170690866285?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27bdf7ec6d
here's my Mocal & GReddy GREX setup:
http://www.trak-life.com/diy-r33-skyline-oil-cooler-with-thermostat/
I went for a Mocal core with dash fittings rather than BSP (which might cost less, but cost more after converters, etc.)
Had a really really good search for fittings... RARELY anything for the 5/8" male outlet on the cooler...
BUT, I did find 5/8" BSP female to 1/2" BSP male and speedflow fittings for 1/2" BSP female to -10AN hose.
So I'll be converting my 5/8" to 1/2" then use speedflow 1/2" adapter for -10AN nylon braided hose.
Can anyone let me know if this idea is ok?
​I understand that the more joints I have, the more chance of problems occurring......
So you need something like this... http://www.ebay.com.au/itm/AN-10-10AN-Male-1-2-BSP-BSPP-Female-Adapter-Mocal-Setrab-Oil-Cooler-/380572024115?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item589bdc3d33
But with a 5/8 bsp thread tapped into it? They may not exist, you may have to modify one and run a tap through it. I could probably help you if you can't find something local. Or you could run the adapters if you have the room...
Really depends where you mount the core, if you mount it where I have it, between the a/c condenser & FMIC, left from the a/c condensor fan you will not have much room available to fit 2x convertors and 2x dash fittings. Unless you mount it just before the wheel arch where it's also commonly mounted.
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
