Hey guys,
I'm trying to build my own oil cooler kit and I need some help with fitting and hoses.
I've bought:
-GREX sandwitch plate with built-in thermostat (-10AN outlets)
-Mocal 19 rows oil cooler core (5/8BSP outlets)
So I'm just wondering what's the best fittings/hoses to use to join both of them up.
I'm thinking of using -10AN braided hoses, so I'll get 2 x -10AN to -10AN hose and 2 x 5/8BSP to -10AN hose? Is that correct?
Also, any recommendations on where I could get them from?
Cheers
https://www.sau.com.au/forums/topic/427723-oil-cooler-fittings/
I used Speedflow fittings and hose (115 teflon / black nylon braid) from motorsport connections in Moorabbin https://www.mscn.com.au
Speedflow seem to be the best fittings I have seen, but check out Proflow as well - I think they are cheaper. Bends etc are not as tight from what I can see but the Speedflow ones are off the planet expensive. A good tip is the straight fittings are much cheaper than any of the bends so if you can get away with a straight its a good thing for the wallet.
Google proflow - lots on ebay and I think you can buy them direct from their website.
Thanks Paul, I've been looking at speedflow and aeroflow, both on ebay. But I can't seem to find any of those fittings for 5/8BSP, as that's the outlet from my Mocal oil cooler... Any recommendations?
Yeah give Motorsport Connections a yell - they haven't failed me yet with being able to adapt to whatever is required. Not sure about ebay but I think Speedflow control the price so generally they retail for same from all dealers.
All the coolers I have dealt with have had AN fittings (JIC) or a metric female boss fitting that you can screw your desired male adapter into. I think you will need an adapter to use the Speedflow stuff on a BSPT but give them a call, tell them what you have to connect and find out your options.
Yeah, my Mocal cooler seems to have a built in male BSP connection..
But will give them a call for sure, as they are close to me too.
Will keep you guys updated :)
Cheers
Mine are all MSCN speedflow! Awesome gear!
^^ +1
I had nothing but issues with Proflow teflon fuel hoses and fittings leaking, TorquesUK has helped me out many times with braided lines for fuel and oil without a problem.
For oil I prefer the black nylon braid rubber cored hoses for oil cooler lines, as it is very flexible compared to the stainless braid. http://www.ebay.co.uk/itm/10-AN10-Nylon-Braided-Stealth-Black-Hose-1m-/170690866285?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27bdf7ec6d
here's my Mocal & GReddy GREX setup:
http://www.trak-life.com/diy-r33-skyline-oil-cooler-with-thermostat/
I went for a Mocal core with dash fittings rather than BSP (which might cost less, but cost more after converters, etc.)
Had a really really good search for fittings... RARELY anything for the 5/8" male outlet on the cooler...
BUT, I did find 5/8" BSP female to 1/2" BSP male and speedflow fittings for 1/2" BSP female to -10AN hose.
So I'll be converting my 5/8" to 1/2" then use speedflow 1/2" adapter for -10AN nylon braided hose.
Can anyone let me know if this idea is ok?
​I understand that the more joints I have, the more chance of problems occurring......
So you need something like this... http://www.ebay.com.au/itm/AN-10-10AN-Male-1-2-BSP-BSPP-Female-Adapter-Mocal-Setrab-Oil-Cooler-/380572024115?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item589bdc3d33
But with a 5/8 bsp thread tapped into it? They may not exist, you may have to modify one and run a tap through it. I could probably help you if you can't find something local. Or you could run the adapters if you have the room...
Really depends where you mount the core, if you mount it where I have it, between the a/c condenser & FMIC, left from the a/c condensor fan you will not have much room available to fit 2x convertors and 2x dash fittings. Unless you mount it just before the wheel arch where it's also commonly mounted.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
